I've got a question for you guys here at Lumber Jocks.
I was always taught when using the table saw to cut angles you make the cut with the fence to the outside of the angle. To be clear, if the blade tilts to the left for angle cuts< which most do, then you would have your fence to the right of the blade and make the cut. And the reason I was told to do this was due to binding issues if done the other way with the fence to the left, or inside of the angle.
And this is the rule I've gone by without questioning it.
I stumbled on this video in which the guy is making a bowling ball from plywood. Which you can watch at the below link:
It's a pretty cool project indeed. And you'll see in the first couple minutes what I'm referencing and has me questioning what I was taught in woodworking let alone table saw safety.
If you watch it you'll notice he makes all cuts on the table saw to the left or inside of the angles. Fence to the left of the blade. No binding. No kickback…
Is this common practice now a days? Obviously this guy makes cuts this way as the norm. Having kick back or binding all the time I would think would change which side of the blade to make these cuts on. Apparently that hasn't happened.
Do you guys make angle cuts to the inside of the angle, fence to the left as he is doing? Was I taught wrong all along?
You all here at Lumber Jocks are far more seasoned woodworkers than I am… what say you?
cheers…
cheers…
