I need two new stools for our Kitchen counter and decided on this ingenious Roycroft Tabouret table design by Elbert Hubbard Circa 1906. This piece features splayed legs with Mackmurdo feet and Roycroft orb carved into two apposing top rails made from QSWO.
I came up with this to scale design. It's 24" high with 5 degree splay and rake. And will have a saddle seat. I added two extra rails for a foot rest.
It will have tusk tenons and tappers legs.
I found the Ana White plan for slayed and raked legs on line. By tilting the miter saw 5 degrees and setting the front gauge at 5 degrees I cut one end of the leg then I slid it through without turning or rotating it I cut the other end and stand them up and mark the inner part with a black dot like in the drawing above, to keep the proper orientation.
I made this template of the leg to shap it on the router table using a template bit after I rough cut them on the band saw.
I made four blanks for the legs by gluing scrap pine together I found in my neighbors trash to practice on.
The first one I cut on the band saw came out like this because of the 5* angle on the bottom of the leg.
So I made this jig for the band saw and set it at 5 degrees to compensate for the bevel using oval head bolts that are screwed into the treaded holes to zero in on the angle.
It workers well but when I turned I to cut the other side of the leg I noticed the jig wasn't long enough and the leg hung over the end and the tapper of the leg will effect the shape of the Mackmurdo feet.
Now I'll either have to rework the jig to have it sit back further from the blade or find another longer pice in someone's trash like I found this one.
When Elbert Hubbard made this table in 1906 I'm sure he didn't have a CNC machine and attempting to make one makes me appreciate the skills it took back then.
I looked every where for plans and help in making this table/stool with no luck. It maybe way past my skill level but I'll keep trying and maybe learn new skills along the way.
Stickley still makes them and I don't think they would share their plans and techniques.
Any comments and suggestion will be greatly appreciated.
Best Regards,
James Mc
