Kobalt Compact sliding 7-1/4-in 10 Amps Single Bevel Sliding Compound Corded Miter Saw
7.5K views 4 replies 4 participants last post by  Sark
#1 · (Edited by Moderator)
Kobalt - Compact sliding 7-1/4-in 10 Amps Single Bevel Sliding Compound Corded Miter Saw (Rating: 5)
Project I'm on is in attic. Long walk w/many stairs. I have a 15+ year old Hitachi 10" compound slide but it weighs almost 70 lbs so I bought lil jimmy who weighs in at 23 lbs. Big difference. Only cutting one bys so it's perfect. Plugged in, pulled trigger and it started. Paid 200. 2 years ago same was $130. Oh well. Nice to have a lightweight saw to carry to jobs. I cut crown flat and I'd use it to cut crown. Surprisingly accurate
#2 · (Edited by Moderator)
I have a Makita 7 1/4" version of the same, it is by far my favorite cutting tool. They don't make it any longer but did make a battery operated version that was nearly identical. When I purchased mine I really didn't think I would use it that much as I already had 10" and 12" miter saws but I have come to love the smaller platform plus blades are more affordable. I had Forrest make me a blade and it really shines. Good luck with the Kobalt I bet you're going to never regret going with the smaller platform.
#5 · (Edited by Moderator)
Correction, mine is not a sliding compound saw, but a simple chop saw. But that's all you need for a whole lot of work. It will chop a 2Ă—4 just fine, and do a lot of the trim molding. As to weight, maybe 10 pounds? For the cost of about $130 it has huge value, especially when doing minor work on-site.
