Alright. I think it's technically still Saturday in some parts of the US 🤓. Got back from my short trip away, hung out with the family, and managed to knock out the testing late this evening. I've detailed my impressions and rankings below. As well as a collage of pics comparing the cuts side-by-side.
Overall Impressions
- Whiteside 1/2" Straight Cut (25,000 RPMs): I already knew this one would cut fairly well from my initial proof of concept testing when setting up my router table for jointing. Whiteside makes some great bits, and this one is no exception. It leaves a very nice finish. Which I would largely consider to be good to go; needing no other sanding, finishing, etc. The only issue with this bit is that it's the most particular/demanding in regards to technique. And thus the easiest to introduce a little bit of snipe and/or low spots across the joint. Yet is certainly something that could be controlled for with a little practice.
- SpeTool Spiral Compression (25,000 RPMs): This one felt like it cut well. At least as good as the Whiteside, if not better. However, the finish wasn't as good as the Whiteside bit. Specifically in two ways. One, it was rougher overall. And two, it seemed to leave a little tearout. It was less demanding in regards to snipe. But the joint edge would certainly require some additional finishing and cleanup.
- SpeTool Cutterhead (10,000 RPMs): This was definitely the most intimidating, at first glance. The thing is absolutely massive. But it turned out to be a joy to run. The feel as I ran it across the cutter was so smooth. Absolutely buttery. It was even the quietest of the bunch. And the cut quality, amazing. So shiny and smooth. While I would say that it's not significantly better than the Whiteside. It cut much easier and was the least demanding of the bunch in regards to technique.
Rankings
- Whiteside Straight Cut (close runner-up)
- SpeTool Spiral Compression (distant 3rd place compared to the above)
I was most surprised by the compression bit. Just not in a good way. The little bit of tearout maybe shouldn't have been a surprise. But I really expected the overall finish to be much nicer. Don't get me wrong. It was far from terrible. But it was nowhere near as nice as the Straight Cut or Cutterhead bits. Without a doubt, the spiral compression bit is going back.
So with that out of the way, we're down to two contenders. Frankly both are winners. The Whitside straight cut bit leaves a very nice finish. It's just more sensitive to technique. Which is not only evidenced by some snipe, but also can feel a smidge "grabby" during the cut if I didn't use ideal technique. It also lacks, comparatively, in terms of cut capacity. Still if you don't have the funds to pick up a cutterhead bit. A quality straight cut bit will be more than serviceable. And will need little, if any cleanup.
This leaves us with the winner (IMHO); the cutterhead bit. While I'd never freehand with this bit, it's dream to cut with when chucked up in a router table. What you can't see in the pics is how smooth it feels when making a cut. It just glides though the wood. What is evident is the finish. Perfectly smooth, shiny, and will need zero cleanup/finishing. As indicated above, I ran this one at less than half the speed of the others. It felt very stable, and I'm confident I could have pushed it plenty faster. But I don't see a need.
Conclusion
While the Cutterhead and Straight Cut bits were fairly comparable in terms of cut quality. The cutterhead is the clear choice for me when jointing on a router. It's the most forgiving in regards to technique, cuts more easily, leaves a slightly nicer finish, and will last significantly longer.
In spite of being very large and heavy, my 14A (2.5 hp) Skil router had zero issues running it. And as mentioned, it was actually the quietest of the bunch. Yes, it's not cheap (around $130). But I expect it'll last just about forever between the rotatable cutters and the 10 additional cutters it came with.
I also learned a lot in the process just in general about using a router for edge jointing. Technique certainly matters. So I'll continue to both fine tune my setup and practice. Yet even with this testing, the largest gap I could find was .0015", measured with a machined straight edge (spec'd tolerance of .001") and a set of feeler gauges. And from what I can tell, it's the result of something I'm doing (either setup or technique) in the last 1-2" of the cut. Which I'm pretty confident in being the culprit, as it was consistent across the bits.
