Inset Doors Won't Sit Flush
4.7K views 5 replies 4 participants last post by  aurora
#1 · (Edited by Moderator)
I was installing a couple of inset doors on an armoire last night using some non-mortise hinges. One of the doors closes just fine and is flush, the other however, won't close flush with the frame without a little bit of force.
I was thinking that I should put a 2 - 3 degree back bevel on the edge of the door that won't sit flush to solve the problem. Has anyone experienced this type of problem before? I don't want to cut the edge of my door if I don't have to, but if that's the only solution, I'm up for it.
#2 ·
I cut all edges/sides of the door at a 2, to 3 degree angle so the door fits tight when closed and then use a block plane slowly taking off thin shavings till it fits perfect. Time consuming PITA but often the only way to achieve a nice fit.
Good luck
#4 ·
Did you check to see that it's not a proud screw head that's keeping it from closing properly? I suspect you did, but thought I'd ask.
It's the kind of thing I miss, late in the day.
#6 ·
have had the same problem a number of times, so i checked out lots of inset doors. found them mostly on old pieces. guess what, they all had the 2 degree back bevel ! so now i always put the bevel on my inset doors, makes it loads easier to fit.
jointer makes the fastest work of it, then touch up with a small block plane. i think it actually saves time if you do it from the start. this method actually compensates for "proud" screw heads that Lee mentioned and crappy hinges which i think were my usual culprit.
good luck !
