How To Make a Track Saw?
29K views 26 replies 17 participants last post by  JohnDi
#1 · (Edited by Moderator)
I would like to use my Bosch circular saw with a track for precise cuts. But in my view, the options currently available on the market are extremely over priced, like the Eureka Zone track system.
I know fellow LJs have made similar setup in the past but the downfall of the ones I have come across so far, is that they use a miter bar attached to the saw base that rides in a dado'd track. This makes the saw not useable without the track.
The commercially available systems use the opposite approach where the dado is in the saw base attachment and the miter bar is on the track. Has someone built a similar system?
For my track saw system, I would like to use aluminum track similar to what Eureka Zone and the likes use in their system. Does anyone know where to buy such a track for cheap? I am sure there must be a wholesale type supplier that wont charge as much.
Thanks!
#2 · (Edited by Moderator)
Not happening. Bite the bullet and buy the Eurekazone.
Aluminum extrusions are not that cheap, even in common
industrial profiles. Steel is a lot cheaper by weight but
cannot be as easily extruded and is too heavy anyway.
Anodizing has real costs and the dies to make an extrusion
like the Ezsmart are substantial.
Look at 80-20 extrusions if you want to fuss with
making your own system. You could make a panel
saw from it…. track saw, I think not.
#5 ·
The wood whisperer did a review which basically said that it's miles better than a regular circular saw, but not as good as the festool saw, mostly in the dust collection area I recommend the video, while marc may be a festool fanatic (I'm just jealous) he does give an honest review of the saw.
But you don't really need a full track system, just a piece of wood that's straight, glued or screwed to a piece of plywood gives you a good enough track, I like my buddy hjt's track http://lumberjocks.com/projects/81555 it works well for him, and I have something similar.
-jeremy
#7 ·
Takes me 30 seconds to remove or attach the bar on the base of my Skil 77. Small price for the improved accuracy and ease of cut alignment. REALLY small price when compared to the cost of a commercial jig that does the same thing.
#8 · (Edited by Moderator)
I would like to do the same.
I think the trick is to put a dado'd track in the circular saw custom base and the guide bar on the custom track. Then you could still use your saw for other stuff. I think this DIY option is still do-able - my eyes are still open for the right (simple design). Still would have to find a wide-ish aluminum track from a metal supplier or somewhere - then to stick on some thin 'router pad' material on the bottom (no clamping required!)
#12 ·
Jeremy, I already have the guide you mentioned in your post. I am just looking for an even more precise guide.
Since starting this thread last night, I have been thinking of an idea of mounting an 8 foot long (or shorter) 1/2" high x 3/4" wide aluminum bar (if there is such a thing) on a piece of 1/4" ply and mounting a thick cutting board on the base of the saw with a 3/4" wide and 1/2" deep dado routed in it. Would that work? I think the main concern would be to ensure the straightness of the aluminum bar.
What do you guys think?
#13 · (Edited by Moderator)
I bought the Scheppach Track Saw when it was on sale through WOOT!. So far it has worked well but I have only cut up one sheet of 3/4 plywood and half of a 1/2 inch sheet while preparing to build some cabinets for the shop.
The Scheppach cs55 track saw is identical to the Grizzly model. I also bought the Grizzly 55 inch track and attachment kit. All fit and work as one unit with no problems encountered.
#20 · (Edited by Moderator)
Aluminum bars cannot be trusted to be straight.
Extrusions like angle are a lot more straight in general.
Steel square tubes are pretty straight. The larger
the cross section of the extrusion the straighter they
tend to be.
Those t-tracks may be straighter than bars. They
are extruded, machined, then anodized. T-track
I have used has been pretty straight.
#24 ·
tool_junkie if you are still looking for extrusions, all kinds from Tslots and 80/20 there are plenty on eBay. There are some 1/2 profiles that look promising.
When I was still working I built a vision inspection system using Tslot extrusions and their linear bearings to move a camera which had to be relocated for the entire inspection. The linear bearings can be adjust for virtually no play.
#25 ·
- Gene Howe
Gene, what is your system? You mention removing a bar, is it the same idea as shown in the YouTube video with the blue Rockler slot-track screwed to the bottom of the guy's saw plate?
#26 ·
Sraightlines, I mortised a T track into an 8' length of Birtch ply and attached the matching insert to the bottom of the saw. Here is a pic of the T track from Peachtree woodworking.
And here is a shot of my jig.
And here is the base of the saw. I use wing nuts on the bolts.
