I have a living room wall that is 146" across from wall to wall. I have built 2 "built-in" bookcases" in each corner 27" wide (basically Norm's "Library System" if you are familiar with it). I would like to have a shelf across the top of these that is no more than 6"-8" deep to set knick-knacks, miscellaneous books or holiday decorations on. Thus the unsupported span between the cases is 92".
I would like the shelf to be no more than 2"-3" thick at most if possible: trying not to have a chunky fireplace mantle look.
To span this without sagging I considered a torsion box architecture with 2x4s and covering with plywood or solid wood, but this is much thicker than I'd want, and probably so heavy that my wife and I couldn't install it ourselves. Also the plywood would only be 8' long and that doesn't cover the entire length. This brings up another issue: would it be better to have an 8' length and then 2 short pieces on each end so that it is easier to build -and- install? Wedging a 12' long piece in there without banging up the walls appears to be a challenge in itself.
The bookcases are painted white. I want this piece to have a natural, light finish; possibly just a clear lacquer. I don't know that I am concerned with exceptional woodworking joinery on this (like mitered corners to hide potential plywood banding) but I don't want it to be ugly either.
What say the group for recommendations for this project?
Cheers
Cheers
