How I Tune Up A Square Drive Drill Bit That’s damaged from Cam-Out
3.4K views 17 replies 5 participants last post by  mafe
#1 ·
How I Tune Up A Square Drive Drill Bit That's damaged from Cam-Out
Cam-out is when a bit slips out of the screw head and damages the screw or the bit or both.
I'm sure many of you already know how to do this but for those new to working with tools this is a simple way to fix your square drive bit heads in a pinch.
This bit is a victim of cam out.
I place the bit as straight as possible in a vice and file down the tip with a corse diamond file. This shortens the bit a little and gets it down to a part on the bit where it's not damaged.
Then I lay it flat on a mat and clean up the burrs on all four sides with a fine diamond file.
Now it works like new.
I tried doing this with a file but the material the bit is made of is as hard or harder than the files I have.
#2 ·
You are a frugal perfectionist James! 8^)
I buy them by the 10-pack and still use the first two or so thus haven't had the need to sharpen yet, but I'll keep this in mind for sure!
Have you tried to fix Phillips drivers? I go through piles of these bastids.
#3 ·
I buy them by the 10-pack and still use the first two or so thus haven t had the need to sharpen yet, but I ll keep this in mind for sure!
- splintergroup
Frugal Smugal. It was my last one! Lol
No I haven't tried sharping the Phillips yet, but I did see an article on how to do it.
But first I must master sharpening the star bits. 8=)
As always, Thanks for the kind and humorous words and thoughts.
#4 ·
JEMI if I ever need a labourer for odd jobs, you're hired!
- splintergroup
Actually I've gone rrs about and turfed all my Philips for Robertsons...
But back to the square drives…
  • 4 diamond files.
  • sandpaper
  • scissors to cut above sandpaper into strips
  • or box cutter and steel rule in case the scissors needed sharpenning and you havent bought the files, yet
  • 1 metal vice
  • 5-15 minutes work
  • manicured fingernails
Just to save 0.50c (as per splinter's bulk purchase)...
So, I will go as high as $2.17 for each of your 12 hour daily labouring remittance (meal breaks not permitted).
If it was my last one, I'd forage around in my rubbish bins (quickly) for a replacement Philips screw and buy a pack of 10 drivers the next time I'm in Bunnings (our HD equivalent)...
I haven't costed petrol and travel time to HD as you'd have to cost that to purchase the items for either scenarion.
BTW, what the hell do you use to break those indestructable square drives… anything similar to this?
I assume it is not classified as "cordless"...
#5 ·
Not sure what your quacking about LBD. But if you can get a good square drive for .50 cents your a better man or duck than me.
Like I said the Square drive was my last one and I tuned it up to finish my work.
I always enjoy when you dip your beak into our swamp.
If your celebrating, Happy Thanksgiving!
#6 ·
... I always enjoy when you dip your beak into our swamp.
- James E McIntyre
Thanks for the wishes JEMI... I don't guzzle swamp water... but a Merlot bath is another story,
#7 ·
- James E McIntyre
Thanks for the wishes JEMI... I don t guzzle swamp water... but a Merlot bath is another story,
- LittleBlackDuck
I also enjoy the Merlot but Cabernet Sauvig-yawn,
Makes me tired.
#8 ·
Nice, but I also buy Robertson drivers by the dozen. And I'm still on my first one.
Buy JIS instead of Philips. They're not tapered like Philips drivers are, so they're much less likely to cam-out.
I like the Vessel Megadora 900 screwdrivers, personally.
#9 ·
I try to use square drive exclusively for my projects because I hate the design of Phillips (almost as much as "flat" blade slotted 8^)
The phillips (drywall screws) get used for construction stuff around the house and being that they are so hard, they take their toll on any drivers I use, especially the Apex bits used with a drill/driver.
I have a few "proper" hand drivers that I reserve for easier stuff like brass hinge screws where lots of torque isn't required. Perfect fit and carefully stashed away so they don't get "corrupted" on drywall screws.
Fortunately, my brother uses the phillips style bits by the 100's in his day job and keeps me stocked. Definitely a decision on finding those with a proper grind and hardness balance!
#10 ·
All good tips.
Splinter when I stared woodworking in 2016, I didn't know why Horton Brasses shipped both steel and brass screws with their hinges until I figured out I was supposed to attach the henges first with the steel then reattach them with the brass.
At least that's what I thought they were for. Unless they added the steel screws in case I (camed out ) the brass.
Splinter what's your thoughts on this?
Nothing last forever. Not lithium batteries, carbide or even diamond blades, bits or files.
#11 ·
FYI, Vessel also has an impact screwdriver (the Megadora 980 ) that's designed for removing stripped Philips screws so you can replace them with something good. Whack it with a hammer, and it drives the hardened tip into the screw while rotating it a little (12 degrees, iirc).
One of the brasses companies includes directions saying to use the steel first, then remove it, and then use the brass screws. Don't recall which one it was off the top of my head.
#12 ·
Yep, Brusso includes the steel screw. Often times trying to find a steel screw that exactly matches your brass screw can be tough, the Brusso's are perfect.
The idea of pre-threading your hole with steel is an oldie, but breaking off a brass screw can be heart breaking 8^)
I'll still use brass plated steel on some hinges just to avoid the heartache.
Dave, I have one of those impact screw extractors, ideal for old car door hinges, gummed up, rusty, and Phillips!
#13 ·
... Dave, I have one of those impact screw extractors, ideal for old car door hinges, gummed up, rusty, and Phillips!
- splintergroup
God tip, nut may be a tad overkill splinter... I've never broken a bit or snapped the head on a brass screw… though I've bluntened a few hammers , hammering the screws in.
#14 ·
I used to hammer in screws when I was a kid, at first I just though they were really cool nails, then I just was too lazy to drill a pilot and go find a screwdriver.
Lately, if I'm being paranoid I'll oversize the pilot holes, put a dab of epoxy into the hole and push the brass screws in.
#15 ·
... Lately, if I m being paranoid I ll oversize the pilot holes, put a dab of epoxy into the hole and push the brass screws in.
- splintergroup
Ahha… still not perfect unless you stain the poxy gold!... I don't recommend using tapered drill bits as it wont let the poxy accumulate at the bottom of the hole = too much squeeze out… though, not a problem if "Midasized".
#16 ·
I think it's important, that we remember to talk to all skill levels, so great to share this info.
Also I love that you recycle it.
Best thoughts and merry christmas,
Mads
#17 ·
I think it s important, that we remember to talk to all skill levels, so great to share this info.
Mads
- mafe
Thanks Mads
#18 ·
