Hi, folks! I'm working on some boxes, and I'm trying to really master mitered corners with contrasting splines.
This is my second try. The box body is oak. The splines are wenge. I cut the slots on the router table with a Rockler Spline Jig using a spiral up cut 1/8 inch router bit.
The result is not nearly as clean and sharp as I would like. I'm posting several pictures.
I was thinking for my next box I would try to make the slot edges cleaner by putting painter's tape where I plan the cuts to limit tear out. I need to make sure the spline is all the way in the slot - - there are a few little gaps at the edges. I need to do a better job getting all of the glue that squeezes out from the spline.
What else? I feel like I'm getting sawdust from the wenge into the pores of the oak. Is that a thing or am I crazy? Can I stop that?
And what's the best way to trim the splines? On one corner the wenge split as I was sawing it and broke off below the edges of the corner. For the rest of the splines I really snuck up on the cut, trimming it bit by bit and then sanding. I've got a small piece glued in the gap and will trim it very, very carefully. I don't own a flush cut saw so I used my duzoki saw. How can I do this better?
I know the best way to get better is practice, but any tips or advice would be incredibly helpful!
- Elizabeth
- Elizabeth
