Friends,
If I should post in another forum, please advise but I need some advice on a bolting application for a safe connection.
In the attached photo, I'm looking to use a 1/2" locking nut. The problem is that these are not readily available for hot dipped galvanized bolts.
All stainless bolts and locking nuts is an option but then I'd have to replace everything at a higher cost than I'd like. The wood is western red cedar so hot dipped galvanized is the most economical but I've been unable to find a standard nylon insert nut but rather lots of "top lock nuts". There is also the option of thread locker but this would need to have a special primer to bond correctly.
I've read that locking washers don't work as well as once thought even though these are easy to source:
https://www.boltscience.com/pages/helicalspringwashers.htm
Anyone have advice or should I just go with a top lock nut or similar? This is for a swing set so I'd like to err on the safe side and not have a chance of these coming loose. For now, I've used toothed washers and have been keeping an eye on the nut tension but would like a more permanent solution.
Thanks!
Thanks!
