Need some advice for an upcoming project. I haven't worked with large slabs before.
Just purchased an eastern white pine slab from A seller on Craigslist. 12+ ft long 26" wide and 3" thick. It has been sitting inside a shop for over 40 years. Dry but not temperature controlled. It's flat, no knots, no cracks, no checking. Pretty much perfect for what I need. It was dark when I looked at it. When I got it home and cleaned it up a little I noticed tons of small pin holes towards the edges of the board. Approximately 1/16" in size. I blew everything off with a leaf blower so if there was any fresh sawdust it's all gone.
I was hoping to start on this project in the next few weeks. I am making thick open shelves for a kitchen. About 25lf of floating shelves. Wanted to have them all cut from the same board so it all looks continuous. It will be going in a timber frame home.
From some quick research it sounds like the holes may be from powderpost Beatles but I have no experience with air dried wood.
Here are the questions I am wondering about?
Is there a quick way to tell if they are still active or have been long gone for years? I can't tell from looking at it.
I understand I can wait it out and see if any more holes show up. If I do this is it a bad idea to start breaking it down, planing, jointing, etc?
Should I worry about keeping it in my attached garage? Any risk of the bugs spreading into the home? I live in Maine. Garage is not heated.
Is it possible the bugs are not interested because the board has dried out for so long? MC was 14-18% measured with a cheap pin type meter. I thought it would be lower based on low light it was.
If they are active should I try a chemical treatment or plan to find a local kiln that will run the board through to kill anything? Anyone have experience with the chemical treatment on something this thick? Seems like you need to soak the wood and this defeats the point of the old dry wood.
I don't care about the holes when finishing i just don't want to bring the bugs into the house.
Any advice is appreciated.
Thanks
Joe
Thanks
Joe
