I have narrowed it down to thes two, Powermaatic 2800b and Nova floor standing dvr. Which way to jump?
Perfect!I put a piece of drill rod or something else very straight in the chuck and set up my dial indicator.
- Redoak49
That even happens in wood (I make a lot of threads in wood rather than inserts - The Wood Whisperer Wood Threads - near the bottom of the blog).Question - on my current DP with keyed chuck I like to use it to tap holes in steel so as to keep the threads square to the piece (I do this unpowered by hand). A nice feature I see on the Voyager is auto thread tapping where it reverses automatically to clean the chips. I read from one user that this feature can t be done with a keyless chuck because the chuck will loosen if driven in reverse. Is this true?
- mbg
Ha - thank you for the reply. So you have replaced the single key with two wrenches for reverse operations - progress.Question - on my current DP with keyed chuck I like to use it to tap holes in steel so as to keep the threads square to the piece (I do this unpowered by hand). A nice feature I see on the Voyager is auto thread tapping where it reverses automatically to clean the chips. I read from one user that this feature can t be done with a keyless chuck because the chuck will loosen if driven in reverse. Is this true?
- mbg
You may notice I have two adjustable pliers next to my Voyager (see pictures in above comment). It appears you re prepared to sacrifice shekels for quality (by buying a Voyager) so I recommend buying a pair of good quality adjustable pliers as they will be required to undo… pick the teeth on the pliers carefully (or leather line) as they may mar the chuck.
You ll love your Voyager!
- LittleBlackDuck
The Albrecht keyless is a $500+ chuck when bought new so maybe it will hold.Junking my keyless chuck. Put on a "real" chuck as I spun too many bits. If you had a gear driven drill, you could probably get it snug enough or use the pin spanner it comes with. Well, just use a key. Maybe a $500 keyless chuck works, but a $100 one does not.
Only manufacturer who dares to publish specs is Palmgren. Should have bought it. I will say, if I had to just dial the speed, I would, but as it is, I drill at a moderate speed for almost everything. I tried some of the high speeds recommended for metals and they did not drill anywhere near as well as slower speeds. My Delta is about a 12 speed. In reality, 3 or 4 would be enough for woodworking.
It would be nice to be able to disable the spring to use my DP for tapping. Or I guess a neutralizing weight. One more project.
When we can venture out again, I will look at the Nova again.
- tvrgeek
Not to add to your frustrations, but I ordered the Nova Voyager in December 2020 with an expected delivery date of February 5th, 2021. Well that day passed, so I emailed them and the reply was more delays expected and will ship late April at earliest. I sent an email to Teknatool asking if the Voyager is being discontinued and am waiting for their response.Ugh - I know this post is almost a year old but I decided to order a Voyager on 1/7/21 only to find out there is about a 50-60 business day to delivery!
I bought a NOS Albrecht keyless chuck on ebay for a great price. I chucked it into my PM 3520B lathe to measure runout and I kid you not there was none. My dial indicator has 0.001" increments. I even re-indexed the chuck and 1/2" shank I was measuring to and nothing. I did the same with my PSI keyless and got 0.0035" TIR and thought that was decent. Makes me feel good about the lathe too. Oh no, now if I do the same in the DP all the runout will be do to the machine.
I also purchased the Wixey DP laser recommended by many and my eyes are all over the new Woodpecker s DP-Pro drill press table but am trying to resist it until my DP is delivered or at least on it s way.
Thanks
Mike
- mbg
I contacted Teknatool and they told me "The cause for such a delay is an abundance of customers and during the pandemic securing overseas shipping containers, has proven to be a beast." So hopefully you will get yours soon. My due date to ship is still beginning of April.Ugh - I know this post is almost a year old but I decided to order a Voyager on 1/7/21 only to find out there is about a 50-60 business day to delivery!
Thanks
Mike
- mbg
I looked online at Woodcraft and some other places today and if you order now the expected ship date is the end of June!
- Newbie17
Where did you order through? It seems almost every store states the product ships directly from the manufacturer. I hope your shipping date is correct because if they ship in order by purchase date, I'll be receiving mine next month.Ugh - I know this post is almost a year old but I decided to order a Voyager on 1/7/21 only to find out there is about a 50-60 business day to delivery!
Thanks
Mike
- mbg
- Newbie17
- mbg
I purchased through Zoro (was able to use 20% coupon) and they too drop ship. Little strange but when I ordered mine their web page said 60 working days and today, 20 days later, if you bought it today it says 40 days. Who knows.Ugh - I know this post is almost a year old but I decided to order a Voyager on 1/7/21 only to find out there is about a 50-60 business day to delivery!
Thanks
Mike
- mbg
- Newbie17
- mbg
- Newbie17
Maybe a $500 keyless will work. A $80 did not. So does a $35 keyed. I was not putting a $500 chuck on a used $300 drill.The Albrecht keyless was the ultimate in the first job shop i worked at (machinist), price in 1975 was about $500. If the quality is as good as then, it would be a bargain now for $500. But it was more than i could afford in an apprenticeship while buying all my precision tools.
- mtnwalton
Can you tell me more about this coupon? I have plenty of time to cancel my order and order from another company. : )Ugh - I know this post is almost a year old but I decided to order a Voyager on 1/7/21 only to find out there is about a 50-60 business day to delivery!
Thanks
Mike
- mbg
- Newbie17
- mbg
- Newbie17
- mbg
I'm guessing a shortage is a shortage wherever you go as it's a manufacturer's issue… I've traveled far and wide and I'm still 4' 15.5" tall wherever I end up.Can you tell me more about this coupon? I have plenty of time to cancel my order and order from another company. : )
- Newbie17
