Grizzly G0453 15" Planer
1 reading
54K views 44 replies 22 participants last post by  Thertualong276
#1 · (Edited by Moderator)
Grizzly - G0453 15" Planer (Rating: 5)
Well As I recently stated….I did some serious upgrades in the old shop in the last few weeks, bought a new cabinet saw, new band saw, new jointer and a new planer. This first review will be over the new G0453 15" planer. (actually my second review…the jointer was a few weeks ago)
I did some serious thinking about which planer to buy….but decided to go with a new Grizzly since I have had such good luck with my Grizzly jointer. While I really wished I could have went with a 20" planer….... I figured I have gotten by for years with my old 12" Delta planer…..so a mobile 15" would be fine…also the 20" was allot more $$$$
I narrowed my choice between the G0453 and the G0453Z. The G0453Z had a spiral cutter head….the G0453 did not. But I KNEW after getting my new 8" Jointer with a spiral cutter head…that I had to have one on my planer. The two machines are identical with the exception of the cutter head, and a slightly different magnetic switch. The G0453 was almost $500 cheaper than the G0453Z AND had free shipping….which made a difference of almost $650. (Warning here….I am pretty good in the mechanical area, and could rebuild a diesel tractor engine almost before I could walk, lol. BUT if your not mechanically inclined…do NOT do this !!! Changing out the cutter head is way more complicated than just taking out a few bolts, you will have to strip the machine almost all the way down)
Here are the web site links for the two machines..
http://www.grizzly.com/products/15-Planer/G0453
http://www.grizzly.com/products/15-3-HP-220V-Planer-with-Spiral-Cutterhead/G0453Z
To buy the spiral cutter head for the G0453 was $495 (also free shipping)....so by buying the G0493, and buying the spiral cuter head seperate…I saved about $170 AND got a back up cutter head….not a bad deal.
I finally put it all together a couple of days ago and used it for the first time yesterday….all I can say is… WOW...smo0th as silk…no vibration….WAY quieter than my old Delta (I guess because of the spiral cutter head)....the over size in feed and out feed tables are great…and it needed VERY LITTLE adjustment out of the box. It was one of the easiest machines I have ever put together.
To anyone looking for a GOOD mid size planer…and not wanting to take out a second mortgage on their house to do so…I Highly recommend looking at the G0453. You will not be disappointed !!!!
#27 · (Edited by Moderator)
Ok it's settled I'm going to order a new planner and put the spiral heads in. I enjoy reading the reviews and comments from everyone, glad I found lumberjocks. Eventually I'll put some pictures of work on the home page. Still undecided on the Shelix or the Grizzly head. The only reason for the Shelix is that it cuts with a shearing action and it might just eliminate some chatter but after reading the jointer review Don suggested it seems everyone seems to have no trouble with the grizzly. After saving on shipping it's just $30.00 more but if it doesn't come with the T handle and extra cutters like the grizzly then it's a deal breaker.
#29 · (Edited by Moderator)
Hi all,
I recently picked up the Grizzly G0453Z planer and spent all day yesterday setting it up. I have checked and tuned the infeed and outfeed rollers, as well as the table rollers to factor specs according to the manual. I have run a few test boards through the machine, but find that it leaves marks (run the width of the board all the way from front to back of the board) that look like it's caused by the serrated infeed roller. Any suggestions or experience dealing with this?
Thanks,
planesmooth
#30 · (Edited by Moderator)
It is the infeed rollers most likely. After running a piece through run it again without changing the table height. The blades won't cut but you can get a good idea of how much roller pressure is on the board. This should be very minimum but will leave slight marks on pine and no marks on hard wood. You can also see how much the roller lifts by looking at the springs on the end of the roller (that's were the adjustment is). If they are fine lines then it might be the out feed roller. After that you can always fine tune from their depending on the type of work you do most.
#31 · (Edited by Moderator)
planesmooth,
I agree with eastside....as has been stated already in this review…..the bed rollers, if set at what the book says (at .010 to .020) will leave snipe…set it between .004 and .002…and the spring pressure for the feed rollers is also to tight (if set at factory specs.)...which is causing your marks in the wood. I just ran scrap wood through mine over and over playing with the spring pressure till it left no marks at all, but still had plenty of power to pull the wood through.
eastside...how is it going with your spiral cutter head….did you get the new one yet…and if so did it make a difference ?
#32 · (Edited by Moderator)
Just a note. I purchased the Rototractor from Grizzly. They sure do deliver quickly. It made adjusting the bed roller very easy. However the one of my roller cams must be defective because when I adjust to .002 and tighten down the set screw, the roller moves back to .004. So I set them both to .004. I still get a little snipe on occassion. I also get the feed roller marks on the first pass with pine but it is eliminated with the second and third passes. The surface cut is amazingly smooth with te spiral cutter head. I don't see a reason to even sand. For me it is important to hold the backend of the board against the infeed table until the board is coming out from the planner.
#35 · (Edited by Moderator)
Don,
Thanks for the review. I have been looking for a planer and was trying to decide between a bench top (DeWalt 735) or a stand alone with bigger capacity. You convinced me that bigger is better. I have had limited exposure to Grizzly tools, so this helps a lot. I noticed that Grizzly's latest add in the November WOOD magazine has the machine on sale for $850 and free shipping. Seriously considering placing that order. Of course, at 675 pounds, I will have an interesting time getting it back to my workshop over 100 feet of lawn.
