Grizzly G0453 15" Planer
54K views 44 replies 22 participants last post by  Thertualong276
#1 · (Edited by Moderator)
Grizzly - G0453 15" Planer (Rating: 5)
Well As I recently stated….I did some serious upgrades in the old shop in the last few weeks, bought a new cabinet saw, new band saw, new jointer and a new planer. This first review will be over the new G0453 15" planer. (actually my second review…the jointer was a few weeks ago)
I did some serious thinking about which planer to buy….but decided to go with a new Grizzly since I have had such good luck with my Grizzly jointer. While I really wished I could have went with a 20" planer….... I figured I have gotten by for years with my old 12" Delta planer…..so a mobile 15" would be fine…also the 20" was allot more $$$$
I narrowed my choice between the G0453 and the G0453Z. The G0453Z had a spiral cutter head….the G0453 did not. But I KNEW after getting my new 8" Jointer with a spiral cutter head…that I had to have one on my planer. The two machines are identical with the exception of the cutter head, and a slightly different magnetic switch. The G0453 was almost $500 cheaper than the G0453Z AND had free shipping….which made a difference of almost $650. (Warning here….I am pretty good in the mechanical area, and could rebuild a diesel tractor engine almost before I could walk, lol. BUT if your not mechanically inclined…do NOT do this !!! Changing out the cutter head is way more complicated than just taking out a few bolts, you will have to strip the machine almost all the way down)
Here are the web site links for the two machines..
http://www.grizzly.com/products/15-Planer/G0453
http://www.grizzly.com/products/15-3-HP-220V-Planer-with-Spiral-Cutterhead/G0453Z
To buy the spiral cutter head for the G0453 was $495 (also free shipping)....so by buying the G0493, and buying the spiral cuter head seperate…I saved about $170 AND got a back up cutter head….not a bad deal.
I finally put it all together a couple of days ago and used it for the first time yesterday….all I can say is… WOW...smo0th as silk…no vibration….WAY quieter than my old Delta (I guess because of the spiral cutter head)....the over size in feed and out feed tables are great…and it needed VERY LITTLE adjustment out of the box. It was one of the easiest machines I have ever put together.
To anyone looking for a GOOD mid size planer…and not wanting to take out a second mortgage on their house to do so…I Highly recommend looking at the G0453. You will not be disappointed !!!!
#8 · (Edited by Moderator)
great review - I think the major difference in noise and vibration between this one and your old delta is the fact the motor more than the spiral cutter. If I recall - the lunchbox planers are using Universal motor assembly- which ARE loud and hyperactive. :)
glad you're enjoying your new board maker.looks like a keeper. I doubt you'll need to upgrade this one in 20 years.
#11 · (Edited by Moderator)
Thanks Jim,
No kidding about how smooth and quite it is…..I was simple amazed….I normally had to put on ear muffs when I ran my old Delta….and NEVER ran it late at night for fear of making the neighbors mad. I have a terrible case of insomnia…..and even though I am known to work in my shop late at night…I never ran any of my equipment that would annoy the neighbors…..As it is with all this new "Quite" stuff….I may NEVER get to bed, lol.
#13 · (Edited by Moderator)
Thanks Tom !!!!
I added a warning to my original review, and thought I would re-add it here for those who already read the review, and are thinking of doing the same thing I did…Buying the unit with a bladed cutter head with the idea of changing it out for a spiral cutter head to save money.
I am pretty good in the mechanical area, and could rebuild a diesel tractor engine almost before I could walk, lol. BUT if your not mechanically inclined…do NOT do this !!! Changing out the cutter head is way more complicated than just taking out a few bolts, you will have to strip the machine almost all the way down.
#15 · (Edited by Moderator)
Don,
I have had the G0453Z for about a year now and am extremely happy with it. The spiral carbide cutters are so quiet and smooth. I have run a lot of quarter sawn oak, cumaru, walnut. cocobolo, cypress, pine and other wood and it does such a great job on all with no snipe after playing around with various adjustments of the infeed and outfeed tables.
I know you will be happy as a termite in a sawdust pile with yours!
#17 · (Edited by Moderator)
Routerisstillmyname,
Well it comes out smooth as glass. In the long run from what I hear it is actually cheaper…depending on what you run through it and how much you use the machine…these blades can last for years. As far as adjusting….there is no adjusting…no setting up etc etc etc. Each blade has four sides, when they get dull you just loosen the screws and rotate the blades. If you hit a piece of metal in the wood, instead of changing out ALL the blades, you can either rotate the ones that were damaged…or change out only the ones that were damaged.
Here is a picture of the cutter head on my Jointer, the planer head is 7" wider and about twice as big around, but other than that, they look enough alike to give you they general idea.
Each cutter blade has a little index at one corner, so you can keep track of where you rotated them. And while the picture does not do it justice (Cutter blades look small) each blade is about a half inch across and a 1/4 inch thick, darn thing looks like a meat grinder.
#20 · (Edited by Moderator)
Don, thanks for the great review. I have some questions for you and i think you are the perfect person to answer. I also have been using the dewalt 12 1/2 table top planer for some years now and i am thinking of doing the exact same thing as you did including changing out the cutter heads. A google search led me to your review and lumberjocks. How does the grizzly handle snipe compaired to the dewalt? I've read some reviews about the outfeed rollers leving marks on the surface were the dewalt with rubber rollers did not. What was your first reaction to this after living with a planer that did not leave marks?
#21 · (Edited by Moderator)
Eastside,
Sorry I did not notice your question. I did have a problem at first with the rollers leavings marks….lucky I was just using cut offs to set everything with. If you just follow the directions…there is four adjustments for the roller pressure…once you set it to the factory recomended settings of roller pressure, all you have to do is play with it untill you get it were you want it. after just a few adjustments…..it left no marks at all. But if you run the roller presure to tight it will leave little marks. Also "IF" you buy the Grizzly planer…..the grease the hell out of it to keep away rust untill it is sold. The rollers are coated with grease and are kind of a pain to clean up.
#22 · (Edited by Moderator)
Thanks Don, I've been researching more about this planer and I think I'm going to order one in the next few weeks. I'm probably going to order the Byrd shelix cutter head which has a shearing cut. It's on sale now and the company that makes it will match Grizzly's price and throw in free shipping to! I downloaded the install instructions from Grizzly and it does look like an all day job but doable. I know what you mean about the grease I bought the Grizzly shaper a month ago and it was loaded. I used lacquer thinner.
#24 · (Edited by Moderator)
I own a grizzly 12 inch and a 15 inch had the 12 inch about 10 years had 1 bearing co bad, ordered a new one and it came in 4 days I have had the 15 inch6 years and not a bit of trobble have change the blades one time. I only run hard wood thru it.I needed to run wider lumber thru it . tat is way I got two planers I realy like them both.no snip on the 15 inch at all good luck
Chuck
#25 · (Edited by Moderator)
Thanks again guys.
Bob,
I am going to buy a Rotatrator, more and more of my equipment is needing to be fine tuned, so I think it will be a great addition to help. I am lucky though in the fact I have a set of machinest feeler gauges that go down to .002.
eastside,
As far as the H7768 15" Shelix Cutterhead Vs. the H7655 15" Index Spiral Cutterhead, since it is on sale, it sounds like a good deal. but after having two different Grizzly tools with their "In house" cutter head, I could not be more happy with them. I am not saying anything bad what so ever about the Shelix cutterheads as I am sure they are great. But for the preformance I have been getting with the Grizzly heads I don't think I would even spend the extra $50 for the upgrade. In another review I did over a jointer http://lumberjocks.com/reviews/705, about a third of the way down where Todd A. Clippinger makes a post and for a few down, we talk about the differance between the Shelix and the Grizzly cutter heads.
#26 · (Edited by Moderator)
eastside,
I forgot you also asked about the snipe. Before I changed out the cutter head, as I was doing all of the adjustments, I did notice a small amount of snipe. But like has already been said several times, after you do the factory recomended adjustments…then do some playing. The factory recomended setting for the roller table is between .010 and .020…even at .010 it left a small amount of snipe. After I set them between .002 and .004 all snipe disapeard. I then changed out the cutter head for the spirial and everything worked great.
