1 - 1 of 13 Posts
Two options immediately come to mind. First, use hide glue or some other easily reversible glue to secure the adapters.
Second, and this may be more alteration to the original piece than you want, place the adaptors into the holes, then put some sort of pin in from the back, angled slightly downward, so it holds the adaptor down when the bit is lifted out. A small brad, maybe, though I’m thinking something that sticks out far enough for you to pull it when you want to remove the adapter. Crude un-artistic rendering:
1 - 1 of 13 Posts
