How do you locate the correct positions for drilling holes in a cabinet door so that the holes align with the pre-threaded holes in the door handles? Paper template? Thin wood template? Just measure?
That is brilliant!! And simple!!Cut the heads off of two screws that fit the handles. Extras from your collection of screws. Tile or grind the ends of the screws to a point. Install them in a handle so they protrude a bit. Locate them where you want the handle to go and press the screw points into the wood. The spots for you holes are now marked. Proceed to drill the hole. Be sure to have a scrap piece of wood clamped to the back side to avoid split out around the hole.
