How do you locate the correct positions for drilling holes in a cabinet door so that the holes align with the pre-threaded holes in the door handles? Paper template? Thin wood template? Just measure?
I bought this jig for my kitchen remodel and it's amazing. It's also very easy to use. I didn't use the guide since all my cabinets are a different width and I just measured the center on all my drawers and marked it on some blue tape on the drawer. Once you set up your jig, just line it up with the center or the drawers, drill your hole about halfway through. Remove the jig, hold a scrap block of wood against the back of the drawer face to prevent tear out, and finish drilling the holes. Just don't be stingy and reuse the same piece of tape for several cabinets because you may get confused on which line is the current center line. Only happened once and it was on the last drawer on the very bottom and luckily the incorrect holes were fairly easy to fix.
Jealous? A box a week guy might not need one, but try doing a kitchen full of pulls and knobs measuring and drilling. This thing is foolproof. Well for most it is. I'm sure there are some out there who would still manage to mess it up.Too bloody complicated…for just a few simple holes…unless one NEEDS to use such a crutch….
- bandit571
But, that's just onesies or twosies. They make a cheap plastic one that might work for you. If I had alot to do on a reg basis I'd take Rich's advice. That slick jig would pay for itself after a kitchen or two.Tape measure, torpedo level and pencil
- 1thumb
I would never even attempt to use something like that. Way too many holes on it and it's cheap plastic. The True Position Tools jig is very well built and American made. Worth every penny.But, that's just onesies or twosies. They make a cheap plastic one that might work for you. If I had alot to do on a reg basis I'd take Rich's advice. That slick jig would pay for itself after a kitchen or two.
That appears to only use a 5mm drill. Doesn't that make for sloppy holes? I use 11/64"- 4.3mm, as 8/32 screws are just over 4mm, and 4mm screws are a little under 4mm.
Works fine.That appears to only use a 5mm drill. Doesn t that make for sloppy holes? I use 11/64"- 4.3mm, as 8/32 screws are just over 4mm, and 4mm screws are a little under 4mm.
- jwoodcraft
Yes, I've seen your work.Been doing this sort of job since the 1970s….just saying…
- bandit571
doesn't mean it's the best or easiest way to do it.maybe youve been doing it the hard way for 50 years ?Been doing this sort of job since the 1970s….just saying…
- bandit571
