I'm now working on my bedroom door after having completed fixing my bath door. As with the bath door, I'm replacing the brass hinges with satin nickel ones. They are the same size as the brass ones: 3-1/2".
I took out the door from the from the frame, removed the knob and sanded it because I intend to paint it.
But this time I'm a bit wiser. Before painting it, I decided to first hang it back onto the frame in order to see whether it fits with the new hinges without a problem.
Here's the problem. After installing the hinges, the door is not rubbing anywhere on the jamb. However, the door feels a bit tight. If I press it into the closed position and let go, it pops out. In other words, it opens on its own. The resistance is not a lot but there's some. Like I said, it opens on its own.
I'm not sure what I need to adjust.
I should mention that I primed and painted the part of the jamb where the hinges go in. I did this because when I removed the hinges I noticed that the person who installed them had an extra hole on one mortise which must have been a mistake. So I filled it with wood filler, primed and painted the mortise. I painted the other mortise just so they matched. Could this have made a difference?
Below are two photos of how the door looks when closed (please pardon the appearance of the door. It's sanded but not yet primed and painted).
