Hi folks. I have been a member for awhile and really enjoyed the diverse input form this community. Im planning to upgrade my track saw system. I have been using a DeWalt 7 1/4-in cordless circular saw and the TruTrac system for about 5 years. Its been really a good start, definitely better than fiddling with straight edges and various shop made jigs to cut a straight line. This setup has been great for a lot of home and outdoor projects, and it was cost effective 5 years ago. However, its lacking in several areas that are critical to me;
1. quality of cut (on the cut piece there is some tearout and splintering on crosscuts of plywood and some chipping on melamine; on the cutoff piece there is lots of tearout and chipping, wasting wood);
2. dust just goes everywhere; there is no taming the circular saw bc of the way the blade guard retracts. I was ok with this bc I did most of my cutting outside. I'm now working throughout the year, and trying to dodge weather events or deal with the cold while cutting outside is growing old.
3. Precision is passable but it is really difficult to dial in a true 90 or any angle.
4. Setting up the tool is time consuming. Circular saws are, by design, cruder tools meant for construction work and not cabinet or woodworking.
Ive narrowed the field to Festool TS 55 REQ F and Makita SP6000J1. They seem to garner good reviews and lots of user support. I'm using these tools more and more, so cost is less of an issue (but we all like to save a buck!), I've learned to appreciate a good tool over price (I've got a few I curse a lot and some I just gave away). I already own the Festool CT 26 so Im more than half way there (you all recognize the rationalizing language and the slippery slope I'm on)… Here are my questions to the community;
1. Does the Makita SP6000J1 really weigh 16 lbs?? That's what Makita website, Amazon both indicate. If so, that is a deal breaker/maker. I ain't getting any younger.
2. Does the Festool have a scoring feature like the Makita or do you have to set the depth to 3mm and then reset to cut depth. Not a major issue, but not as quick as the Makita either. I think the added splinter guard Festool has offsets the need to score, am I right?
3. How good is the Makita dust collection? Really? I've seen only one video where the guy evaluated how much dust wasn't collected while comparing the Festool to the Wen, and the difference was abundant, both visually and volume of dust. This is another deal breaker/maker to me.
4. Is the Makita stabilizing feature where it "locks" the saw on the track during bevel cuts that important?
5. Does blade thickness matter? Has anyone noticed? Festool blade is 2.2 mm and Makita is about 1.8 mm. Is this critical? Can different blade thickness be used on different saws, as long as the blade diameter and arbor match or are you stuck using a single manufacturer's blades?
6. Power - I read the Festool is underpowered when connected to the CT vacuum to keep the combined amperage (?) low to avoid tripping circuits. True? An issue? I mainly plan to use this on sheet goods and if I cut hardwoods I would likely make multiple cuts. That's what I do now…
Ok Thank you all!
Ok Thank you all!
