Cutting the Perfect "U" Shaped Sections in any Wood
12K views 15 replies 8 participants last post by  SMP
#1 · (Edited by Moderator)
I want to cut the most perfect "U"-shaped sections out of this plywood as possible.
Typically this involved cutting straight, then drilling a hole for a jigsaw blade, then cutting the lower section of the "U" to connect them. This works relatively well for sheet goods, but I've been trying to do it for dimensional lumber (2Ă—6s) and I never get the "Factory Finish" cut that I'm looking for.
Here's what I've tried -
1. Router - Kind of forces me to use a template, which is a pain to setup and of course leaves a tiny curve where the router can't get to the corners of the U.
2. Table Saw + Miter Saw Combo - I liked the idea of using the Table/Miter saw because I could ensure a very straight cut, but of course the arc of the blade never allows me to get to the true end of the cut.
3. Jig Saw - This is the most obvious solution but my freehand abilities with a Jigsaw are "OK" (even when I use a straight edge) and more importantly the jigsaw blade never gives me that even of a cut vertically (especially on thick stock like 1.5") so the final surface is always uneven in one dimension.
.. I'm looking for some new techniques.
#3 ·
Do two saw kerf, whack the bulk of the waste in between with a chisel, pare to final depth.
Or use a plunge router to smooth the bottom to final depth. (the router on the edge, not on the face to avoid rounding in the corner)
#7 ·
Turn it on edge and hog it out with a dado stack on the table saw.
- bondogaposis
^Like this^
It also depends on: how long of pieces, how many pieces, how many cuts in each piece, what the size of the "U" is, it all goes into the decision making.
I have stacked 20 pieces together and used a straight edge and a router before. But like I say, it just depends.
#11 ·
Not sure how people are making round corners of the U with a dado stack.
- SMP
They re not. Us people, looked at his picture. What he is calling a "U" is actually a square cut out. ;)
- LeeRoyMan
Oh I thought his problem was that he wanted to turn his notches in the picture into U's. Oh then yeah, for notches a "good" dado stack.
#14 ·
A lot of people have different terminology for things, but a picture is worth a 1000 words.
Since he posted a picture I'm 99.9% sure that's what he is after.
Then there is also this:
"1. Router - Kind of forces me to use a template, which is a pain to setup and of course leaves a tiny curve where the router can't get to the corners of the U."
But I could be wrong…
I guess we'll just have to wait for clarification. :>0
#15 ·
Well, I think you are correct LeeRoy. I must have missed that part where he mentioned the corner fillet as the particular issue he is having.
I guess in a strange sense, the fillets do make it a "U" and it's not that he wants help in creating a "U" but in notching a shape without the fillets.
