Cutting a round hole in Fiber Cement (Hardie) board?
104K views 13 replies 8 participants last post by  dfletcher
#1 · (Edited by Moderator)
Okay this is more workshop that woodworking related since I need to make some holes, specifically 5.125" holes to accomodate my AC hoses for my garage workshop. A jigsaw worked wonders in the Masonite that is getting ready to get yanked off the house this weekend (testing purposes you know…
Now the new stuff going on will be Hardi Panel. Specifically for this piece, the Cedar Mill non perforated soffit board. Run up with some Hardi Trim in their version of rough sawn cedar.
So folks, just how on earth am I supposed to make holes for things like oversized dryver vents?
#6 ·
Do not use a hole saw to cut a hole in Hardie board. All it will do is grind the teeth down to nothin. I'm speaking from experience, $25 hole saw now just a hole. use an angle grinder, it kicks up lots of dust, but it works great. Just have someone hold the shop vac next to the grinder and you'll catch most of the dust.
#7 ·
dbhost: sorry, I thought my HF hole saw set ha bigger than 5-1/4", my bad.
thewoodmaster: at $5.99 a set, it might have been worth it to get a few holes before having to toss the one size.
I do have an adjustable carbide tip circle cutter for cutting circles in ceramic tiles, and have used it in cement backer board, and also use the roto zip tool often with the carbide bit. I was offering the HF holesaw option as a cheap, one shot method.
#11 ·
So my thought process of using say my Jig saw with a RemGrit blade isn't off base? Those blades are kind of thick, so I was thinking about drilling a series of holes with my hand drill, then jig sawing hole to hole, cleaning up with a rasp. This will all be hidden behind a basically oversized Supurr vent anyway, I am just trying to get the port through the wall, and keeping creepy crawlies from coming back through…
I could probably manage with a cabide spiral cutting bit in my Dremel. No roto zip to work with. Had one, didn't use it for at least 10 years, gave it away…
#12 ·
dbhost, your right, using that blade, you will cut through it easily, (like a hot knife through warm butter.) If you draw the circle, place one good hole, insert blade and your done. The finish cut is pretty nice, I usually will hit it with some 120 grit sandpaper to make it pretty, but that would be all you need.
Just make sure to seal any area you have cut with the paint you are using. If you don't, it voids the warranty. Water will get in behind the paint and cause bubbling and peeling.
#13 ·
I was planning on hitting it with about 2 coats of the paint on the cut surface, and once the port is in place and mounted, sealing any gap between the port and the hole with that 50 year silicone caulk, and this is prior to putting the louver over top of that…
I am assuming I should drill pilot holes for the screws and possibly put a dab of silicone on them to seal the Hardie at the screw holes for the louvers as well. Is that right?
