Cummins MCS1000 as first lathe?
17K views 6 replies 5 participants last post by  wormil
#1 · (Edited by Moderator)
The title pretty much says it all. I have the opportunity to buy a Cummins MCS1000 4 speed lathe and chisel set (cheap) for $100 obo. I know its not a Jet or Grizzly but would it be an acceptable lathe to learn on? I have a bunch of oak branches and logs from a fallen tree to practice on. thanks in advance!
Brandon
#2 ·
#3 ·
Hi Brandon
Read this link:
http://lumberjocks.com/topics/17003
My inclination is to pass on it. If someone wantʻs to give it to you then itʻs a good deal.
If you save up $100 more you could get the cheapest mini lathe from Rockler. Several people start out with that model. Of course if the tools are good ones, then $100 might be a good deal…. if theyʻre cheap turning chisels, then not.
#4 ·
Thanks for the responses!
Alex, you make a good point. I may have very little money for tools but I think this particular tool may be "too cheap". I will probably be better off going with a better known brand if I go used or, like you said, I can save up and buy a new budget lathe.
I think I am going to pass. Thanks guys!
