And should I put on paste wax on my magnificent DeWalt DWS779 miter saw to stop it from continuing?
(It looks a hundred times worse in this picture than it really is.)
I maintain 1500 tools here in Hawaii for a tool library. Our location is 50 yards from the ocean. The salt air will oxidize aluminum and cause pitting on steel or cast iron. I use fine grit wet/dry sandpaper to remove the worst and smooth out the surfaces. Once pitting is too bad it is hard to smooth/slick the surface of table saws etc. Then I was treating with paste wax but it doesn't remain for long. Treating with a spray that leaves a lanolin coating seems to work best. You don't want to treat with something that will leave too much residue that might stain wood materials. It is a continuous maintenance situation.
TIA
