Recently picked up an Acacia ButcherBlock counter top for a side cabinet. The intent of the cabinet (and top) is to keep various kitchen appliances/stuff and will not be used to prep vegetables (so, presumably the top will have appliances etc scraped across as they are moved for use). The top was inside a cardboard box, with a placard inside which provides various details, including cutting/securing/finishing. Unfortunately, this placard was not accessible at purchase. The label on the box stated the product was unfinished, as reiterated by staff. It was my intention to finish the top with some hard surface polyurethane or similar to mitigate any wear/scratches.
However, I now find the placard states in large letters "Unfinished", but then is immediately followed by "This product is pre-finished with refined high quality Hardware oil..." and then describes a finishing process (prior to install) of multiple coats of Hardware oil. I should also mention the top has been cut to size, so not returnable (if that is even an issue).
So, my questions - I know pretty well nothing about finishes/compatibility - How do I actually determine if the top has been pre-finished? Cutting shows no evidence either way. If it has been pre-finished as described, can poly be applied on top, with no compatibility issues? If it has been pre-finished and further coats are applied, is that finish oily to the touch and will it affect items like paper etc laid on top? Any advice is welcome.
Marv
Marv
