Boatbuilders V chisel or what ever it is called... Help!
6.8K views 23 replies 17 participants last post by  mafe
#1 ·
help…
Picked up a bunch of wonderful old tools for just around 100 USD (550 DKK), think I made a quite good deal, at least I am really pleased and at the end of the day that is what is important at every deal we make.
Amongst the tools were this beautiful old chisel, my first thought was a corner chisel, but the old carpenter told me that it was a boat builders chisel from a small Danish island, also some of the other tools came from there.
So boat builders out there HELP?
No matter what it is, I can use it as corner chisel and I think it is so beautiful, that I needed to give it back life.
Here are all the stuff I brought back home with me that day and got for 100 USD.
Will do a quick tour top down, left to right.
Long adjustable wooden beam clamp, hand forged hook, 2 profile planes, Gouge-Shaped Adze, Gouge-Shaped Adze head really old hand forged from the boat builder, jointer plane, corner chisel, short beam clamp, piano makers clamp, wheel key, eel scissors, 2 profile planes, wooden brace with three bits (really love this one), hand forged carry hook, blacksmiths pliers, beautiful curved stair saw, boat hook, hook, rabbet plane, dovetail plane, rabbet with cutter, a sugar pliers and one more long adjustable wooden beam clamp.
Since the handle had a part broken of and a long crack down the center of the handle, I found it time to give it a new handle.
So I split the old handle and threw it in the stove for fire, then picked up a piece of beech from the fire pile.
A hard blow with the axe, gives a fine crack.
Splitting with the froe, this will secure me I work along the fibers so I get maximum strength.
A little rough shaping and cleaning up with the hatched.
Since my shave horse works as bench outside at the moment, I just clamp up the wood in the workbench and attack it with the drawknife, again trying to feel the wood and follow the grain and fibers, this will also help to dictate the shape.
Getting there.
Testing the thickness, length and feel with my hand.
Shaping the end, this will help it not to split when you give it some beating later.
Saw, yes even in Japanese style here. ;-)
Drilling a pilot hole for the tang.
With this wonderful old drill bit.
Then I used the beautiful reamer bit to make a hole fitting the tang, beat the handle down over the tang, with a knife final adjustments where the tang meets the handle and the job was done.
Now it just need a little sharpening.
Ohhh yes and my brand.
That's it, ready for future use, life given back to the beautiful old tool.
Perhaps it can inspire others to bring life back to old tools, perhaps just bring a smile, no matter what, I enjoyed the time I spend.
Best thoughts,
Mads
#6 ·
Nice find Mads. I too have thought many times, if only these tools could talk, and tell us what they've done, where they've been, about the men that used them, and what they helped to make. They look to be in very well kept condition, the planes are beautiful.
#10 ·
Beautiful tools! As usual, I love the attention you give to them.
Unrelated question, I saw the drawknife you use has French handle style (?), I'm thinking of getting my first drawknife in that style with the ball like handles. Do you have any thoughts on pros/cons vs standard English/American handles? Thanks.
#17 ·
Hi Mads,
Nice find on that whole collection.
That chisel is a puzzle. Maybe I am just use to timberframing corner chisels but something about that seems off. Most mortises are deeper than they are wide, so is seems odd that it is so short compared to its width… unless of course it has just been used and sharpened so many times that that is all that is left of its length. OR maybe on boats, mortises are wide but shallow?
Most corner chisels are also pretty stout because they take a beating cutting cross grain They typically resemble two firmer chisels at right angles. The blades on that seem remarkably thin when compared to the width.
Makes me wonder if it was something more along the lines of a boat caulk removing tool than a corner chisel. Before you sharpened it, was their evidence of it having a keenly sharpened blade?
Awesome find…Yes if only these old tools could talk. ;)
#19 ·
#22 ·
Hi,
Yes I guess I am a lucky bastard. ;-)
Nisker found the answer to my question and even here in Denmark. Thank you.
I also often wonder what the tools could tell if they could talk, but also feel they do talk, they usually tell if the owner cared for them and used them with thoughtfulness.
Swirt I am impressed by your thinking, you came quite close.
siavosh, yes I have quite a few draw knifes and some of them with egg / round handles. I really like the round handles, especially on the small once, they are more versatile than the long straight handles and let you easily skew the knife.
All, thank you for all your fine comments, it always makes me smile to see your around.
Sorry I am not so active my self on the replies these days, I am mostly in the workshop these days, since they rebuild in my apartment building and I cant cope with the noise, and I only have a slow cellphone internet here.
Best thoughts,
Mads
