Big gulp underneath a tablesaw
7.8K views 19 replies 13 participants last post by  History
#1 · (Edited by Moderator)
So after a couple of failed attempts to come up with a way to fasten a box under my 80's Craftsman contractors saw, I turned to the internet and found this thing…
Concept looks good. Think it would work for underneath? Don't know if the flange is flat all the way around though.
#5 ·
this is what I use on my ridgid table saw. It works as it should on my saw but i have a 1 1/2 border all around the bottom of the saw where it meets the funnel and it does pile up a small amount of dust. I added a piece of cardboard on the back of my saw with magnets to make the opening smaller and this fixed my problem. now if i could find a way to keep saw dust from spraying out of the gullets onto the top of my table saw ( yes I am using a zero clearance insert) i find the dust on top of the saw increase when I use a rip blade in stead of a crosscut blade - any suggestions ?
#6 · (Edited by Moderator)
I use the large shroud from the Harbor Freight Dust Collection Accessory Kit on my C'man 113 TS.
It is just a friction fit, between the base & cabinet. It collects most of the dust, but dust does accumilate on the lip around the edge and does need to be vacuumed out occasionally. I have not sealed the back, around the motor, as 1yeldud1 has done. That is on the shop "To-Do List"!!!
#7 ·
It will work, I got one under my Ridgid contractor saw. Took some doing to get it installed, but now that it's in I haven't had any problem with it.
Worked so good, I put one on my joiner too!
#11 · (Edited by Moderator)
I wish that I would of caught this thread sooner. I have a better dust hood that is more efficient, and is made from sheet metal, which makes it self grounding if your saw is grounded properly. With the Big Gulp, you'll either have to bend the hose or add an elbow to route the hose out from the bottom of the saw, both procedures are CFM killers. I have made these in several different sizes, including a custom size.
#13 · (Edited by Moderator)
Gotter dun!!!
A little door insulation around the edges and it pretty much fit right up. Had to trim a corner so it would fit around a bolt, but other than that…
I have some sign magnet that I use to close off the back. I'll have to play with it to see if it's worth leaving the back off or not.
And I took a couple of extra magnet pieces and put them inside sloped down to keep it from piling up on the sides.
#16 · (Edited by Moderator)
The big gulp is flat all around the edges, I use on for my lathe. You might look at this as well, not quite as tall and may be easier to manage under your saw. I used this one for years under a Delta, and it worked fine….made by the same company as the big gulp. I stuck mine on with double coated foam tape.
edit in: Oops, sorry…didn't see the post where you already ordered one.
