Hi, seeking some advice on a DIY varnish-oil recipe for exterior patio use: furniture, railings, benches (no walk-on surfaces) exposed 365 to rain and intense central California summers with temps to 110 and higher. The wood in question is redwood 2x4s from HomeDepot, either con heart or con common, mostly the latter going forward due to cost. See photo of work in progress. A handyman builds, I finish/install.
The ingredients:
Can I get a vote on a preference for one of these blends?
Thoughts, ideas?
PS: you could be thinking, why not just use Watco or Minwax Teak Oil Finish and call it a day? Yeah, could do that and did on an oak cast iron bench that’s weathering well, 2 yrs and counting. But where’s the fun in that?
BTW, I’m tinting the oil with burnt umber universal tint for a dark walnut tone to match pre-existing HD Behr “stained” surfaces in other areas. The tint worked well on the oak bench for a recent tune-up coat.
7 of these. This is 8ft, others 4-6ft range line edge of patio. Originals rotted out after 25 yrs.
The ingredients:
- McCloskey satin spar varnish - good sun/water resistance, takes sun better than spar poly (tied both on an oak bench, poly a massive fail). I want a flat to satin sheen.
- Pure tung oil – expensive but strong water protection, deep absorption on hard woods.
- BLO oil – cheap, and also deep absorption but lousy on water protection. Little to no protection per Bob Flexner. Why bother?
- Paint thinner/mineral spirits, non CA version from Nevada. Our CARB is dumbing down everything in sight. The CA version leaves a fine oil film behind on “drying”.
- Equal parts varnish-tung-thinner (1:1:1). The tung for it’s strong water repellency. Tried 2 coats on some scrap, water beads really well.
- Add BLO with the same 1:1:1 but cut the oil 50:50 tung/BLO. Save a buck with the cheaper oil at expense of water protection, or would it matter?
- Recipe from HW Kuhn’s Refinishing Furniture(1977):
- 4 parts varnish
- 2 parts half BLO/half tung
- 6 parts thinner
- Recipe from AI, ChatGBT (yeah, I get good info there on everything) where I stressed EXTERIOR use:
- Same as 1) above but add 1 part BLO, so 4 parts for 1:1:1:1 with both oils. Sounds plausible, but what's the BLO bring to the party? Unless I want more oil but at lower cost? I would not mind a flatter less "varnishy" look though the varnish is satin.
Thoughts, ideas?
