I've always used the higher speed for resawing (18" saw & its about all I do on it).
What would one use the lower speed for?
Depends on the speeds
What saw is it? Once you know what the speeds are for it, you can determine what it is designed for… here is an example found floating around the web:
For the Delta 14" Wood/Metal bandsaw (aka: 28-3xx), here is the speed chart for various materials:
- MrUnix
That was from a 1943 Delta ManualHow old is that saw? Note item #3 in the second list: "Asbestos, Sheet"
- JeffP
