Need some assistance from LJ's who have experienced this problem
My 14 inch Grizzly that I resaw on seems to have a problem with its cast iron table. the rear not being in alignment with the front along the blade slot. I think I've adjusted it but I'm not sure so ?
My blade was not at 90 degrees initially so I tweaked the table for straight cuts. I made a resaw jig for small logs and experimented with Lennox and Olsen blades on green lumber. Had some success. :<)
That was awhile back. Had recent success with my chainsaw milled black walnut making veneer. Recently I attempted to use the miter gauge to hold some dowel rod perpendicular to the blade while doing thin free hand slices.
Problem: Using the miter gauge that comes with the saw I'd get stuck as I was moving past the blade slot in the table. The pin is there. There is an adjustable bolt to support the far left corner of the table. the trunions appear to be cast aluminum. ( No I've not looked at them before)
Keeping a square to the blade I adjusted the bolt and trunions. It passes now but there is still resistance that suggests the rear to be out of alignment with the front. ( I didn't think that was possible until Paul Sellers discussed had plane distortion in the sole of the plane)
Thanks for your assistance!
