Covering for air dried lumber?
Forum topic by MattD posted 09-10-2007 05:51 PM 1318 views 0 times favorited 5 replies Add to Favorites Watch
View MattD's profile
MattD
150 posts in 4799 days
09-10-2007 05:51 PM
Can anyone recommend a material to cover the top and sides of a stack of lumber to be air dried? Awhile back, I saw a documentary where a waterproof, but air and moisture permeable material was used to completely cover stacks. It provided for air movement, but protected the stack from sun and rain.
Thanks!
-- Matt - Syracuse, NY
5 replies so far
3810 posts in 4876 days
#1 posted 09-10-2007 06:04 PM
I just use those cheap polu woven tarps and they seem adequate.
You can put a couple of stickers across the top of you stack to let the air circulate better.
35226 posts in 5255 days
#2 posted 09-10-2007 06:05 PM
Old tin roofing works also. But the poly tarp is a good choice.
Make sure you put weight on top of the pile. The top layers will warp if not held down. Cement blocks, cylinder blocks, old refrigerators. some thing.
View Dadoo's profile
Dadoo
1790 posts in 4845 days
#3 posted 09-10-2007 06:33 PM
Hey neighbor! Most people I know use a polytarp. It can be easily replaced. I’ve also seen tin roofing panels used but the pile was allowed to sit too many years and got spunky.
-- Make Woodworking Great Again!
View frank's profile
frank
1492 posts in 5060 days
#4 posted 09-11-2007 02:08 AM
Hi Matt;
—-all above are great answers, but I’ll toss in a new one….
I’ll often use left over sheets of plywood….and then what I use most is the heavy mil. of ‘back plastic’ rolls that you find at Home Depot and such. In my experience the black plastic will outlast the poly tarps. I have stored whole disassembled post and beam barns under the black plastic for a couple of years and still have some beams out behind my barn now that have been sitting under black plastic for 4 – 5 years.
The poly tarps give out over time and are expensive compared to the black plastic….
....which means this is only my two cents worth of opinion.
Thank you.
GODSPEED,
Frank
-- --frank, NH, http://rusticwoodart.tumblr.com/
View Tony's profile
Tony
994 posts in 4885 days
#5 posted 09-11-2007 09:53 PM
Dont waste money on expensive products – use anything that keeps the rain off and lets the sides and ends breath.
