Cutting dados for plywood thicknesses
Forum topic by jstewart posted 08-26-2007 12:37 AM 2020 views 1 time favorited 8 replies Add to Favorites Watch
View jstewart's profile
jstewart
141 posts in 5588 days
08-26-2007 12:37 AM
Topic tags/keywords: dado blade plywood
I’m in the market for an 8” dado set. I’ve noticed that some blades tout their ability to cut plywood thicknesses (such as 23/32” for 3/4” plywood). For example, the Freud SD 508 has a 3/32” chipper that allows for this use. However, the Freud SD 208 is adjustable by 1/16” increments. Does that mean I won’t be able to get tight dados for working with 3/4” plywood?
-- Joshua, Olathe, Kansas
8 replies so far
View Bill's profile
Bill
2579 posts in 5658 days
#1 posted 08-26-2007 01:05 AM
Well not all 3/4” plywood is actually 3/4. Sometimes it is a bit smaller. Also, if you look some of the other types of plywood are like 23/32, etc. A slight difference, but it could make your dado not fit well if you cut it for 3/4”.
With all the adjustments in there, I would think you should be able to match up your plywood with the dado.
jstewart
#2 posted 08-26-2007 01:11 AM
Right. That’s why I was asking. What I should have asked… Do the shims in a dado set allow for enough adjustment to be able to make a 23/32” cut? Or do I need to buy a dado set that has allows for 1/32” adjustments?
35301 posts in 5897 days
#3 posted 08-26-2007 03:05 AM
Joshua:
How’s the baby doing.
The dado sets should be able to do nominal sizes. 3/4” would be normal lumber sizes.
jstewart
#4 posted 08-26-2007 03:49 AM
The baby is great. She’s slowing down my progress on all sorts of household tasks, including my woodworking.
View mot's profile
mot
4928 posts in 5533 days
#5 posted 08-26-2007 07:31 AM
In my experience with dado sets, you can never have too many sizes of shims. I typically take a digital caliper, measure the plywood, then measure the stack, add shims, remeasure the stack, make a test cut and adjust from there. The process takes a few minutes. You can make a router jig to do the same thing and have it take marginally less time to use the stack and shims. I have the 508 and use some Lee Valley Shims with it just because I’m more intimate with their actual sizes….and, “What karson said.”
View WayneC's profile
WayneC
14359 posts in 5594 days
#6 posted 08-26-2007 08:40 PM
I also have the SD508. Here is a link to the shims tom is referring too. Figured I would add them to the post since I went and looked them. Think I will be buying a set. They are $7.75 US.
http://www.leevalley.com/wood/page.aspx?c=2&p=30063&cat=1,41080,41165
Dick, & Barb Cain
8693 posts in 5796 days
#7 posted 08-26-2007 11:23 PM
You can go the cheap way, & cut some out of paper, or cardboard.
This comes from being a depression baby! LOL
View Sawdust2's profile
Sawdust2
1466 posts in 5584 days
#8 posted 08-27-2007 03:52 AM
If dollar bill is 1/128th of an inch it would take a few bucks to make 1/32nd.
Oh, yes. Paper, not dollar bills.
Buy the shims.
