montgomery ward radial arm saw router attachment
Forum topic by baysidebuz posted 01-31-2009 05:07 AM 4245 views 0 times favorited 3 replies Add to Favorites Watch
View baysidebuz's profile
baysidebuz
2 posts in 3967 days
01-31-2009 05:07 AM
I am in need of the router attachment for a 10 inch MW radial arm saw. it is a small piece that threads onto a 20K rpm shaft and accepts a 1/4 inch router bit. The New England company that supplies old MW parts no longer has that part.
Any help that may be provided will be truly appreciated.
Thanks,
baysidebuz
3 replies so far
View thinker1's profile
thinker1
31 posts in 3970 days
#1 posted 03-11-2009 08:42 PM
ther was a jock on here that made arm for his i can not think how it was but if you search this it should pull it up
-- happy wife great life!!!!!!
View Cobijones's profile
Cobijones
5 posts in 2820 days
#2 posted 03-24-2012 07:09 AM
The chuck from a porter cable router fits and gives the option of using 1/2” bits.
View Sigmund's profile
Sigmund
1 post in 1211 days
#3 posted 08-17-2016 08:41 PM
I am considering purchasing a Powr-Kraft RAS for use as a overhead router. One of the aux spindles is 20,000 rpm but requires an adapter with a 15/32-20 thread. The latter is harder to find than hen’s teeth. Mr. Cobijones used a chuck from a P-C router which he said fit the threaded spindle shaft. What was the model number of the P-C router used or would a chuck from any P-C router work? I am new to Lumber Jocks and appreciate your help. Thanks
