Forum topic by Straightpiped | posted 11-03-2008 03:54 PM | 945 views | 0 times favorited | 7 replies | ![]() |
Newbie here with my first question. I am building what would appear to most as a china cabinet. To keep a long story short, I stained part of it one day and another part three days later. The were completely different parts with natural breaks seperating them. When I stained the second part the stain changed horribly different. It is a MinWax stain, can’t remember the name but its like Walnut color. Which the first stain turned out great. The second turned into a real dark red color. I am trying to find out what caused this so I make sure it never happens again. Both staining sessions were done in the same place. Thanks for any advice… -- T. Nelson |
7 replies so far
#1 posted 11-03-2008 04:18 PM |
Hate to ask to obvious, but did you stir the stain both times? The oil based stain pigments settle out aand could cause this to happen. -- Lew- Time traveler. Purveyor of the Universe's finest custom rolling pins. |
#2 posted 11-03-2008 04:22 PM |
lew is right if the pigments seperate and you don’t mix it again you get different colors. -- Roper - Master of sawdust- www.roperwoodturning.com |
#3 posted 11-03-2008 05:38 PM |
I did mix them both times. I guess I could have not mixed it well enough. I have already thought about this and wasn’t sure if this was something that just happens sometimes with Minwax. -- T. Nelson |
#4 posted 11-03-2008 06:35 PM |
that or sanding to the same grit. normally that only affects the depth of color rather then the color its self. I have used the minwax conditioner and it helps on some woods, though if you forget on one piece it will come out much darker (don’t ask how I know that) it keeps one piece of wood from absorbing more stain than another -- Fred, Springfield, Ma |
#5 posted 11-03-2008 07:13 PM |
There may be a couple of things happening. First, what type of wood are you useing? Some woods react with sun and or light and begin to turn color naturally. such as Padauk and Cherry. 3 days don’t sound like enough time for this option. Could be diffence in grain direction, but I dont’ think this is likely as well. Second, were you using any other products in the same area? Using a product such as WD-40 from an areosol can can sometimes leave a resude on peices near by from overspray (this happen to me before.) If you used a stain, not a dye. the color should be fairly shallow in the wood. you should be able to sand off down to the same grit and restain. If you used a dye, it will take a bit more work. -- Greg - Charles Town, WV |
#6 posted 11-03-2008 07:13 PM |
Other than frequently stirring your stain:
Just some thoughts… -- 温故知新 |
#7 posted 11-03-2008 07:37 PM |
I see alot of the points that your all making. There wasn’t anything even close to it that could contaminate the stain. Maybe I need to eat this one up as not properly mixing the stain each time. -- T. Nelson |
Forum | Topics |
Woodworking Skill Share
12697 |
Woodturning
2572 |
Woodcarving
516 |
Scrollsawing
377 |
Joinery
1663 |
Finishing
5778 |
7383 |
30737 |
CNC Woodworking
268 |
Hand Tools
5986 |
Jigs & Fixtures
1624 |
Wood & Lumber
6839 |
1516 |
Focus on the Workspace
2415 |
1230 |
Woodworking Trade & Swap
5146 |
LumberJocks.com Site Feedback
2323 |
Coffee Lounge
9353 |
