Forum topic by willhime | posted 06-23-2022 05:59 PM | 729 views | 0 times favorited | 29 replies | ![]() |
Topic tags/keywords: jig question resource tip trick Maybe I’m not a good internet sleuth but I can’t seem to find any information on the pink studs at lowes. Is there a reason they’re cheap ? And is the pink a caustic chemical like pressure treated wood ? -- Burn your fire for no witness |
29 replies so far
#1 posted 06-23-2022 06:21 PM |
Are they pink or heart wood? -- Whatsoever thy hand findeth to do, do it with all thy might |
#2 posted 06-23-2022 06:31 PM |
i believe it’s a fire retardant or possibly a type of pressure treating.but if that were the case id think they would cost more ? -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#3 posted 06-23-2022 06:45 PM |
I’ve never seen true “pink” studs at Lowe’s but I avoid that place as much as possible. I have seen a lot of pinkish and red studs that are cut from the heart of trees. Assuming that’s not what you are talking about I found this online “ That pink preservative protects the lumber against fire, mold, fungus and rot.”. Like already said though I’d think that would make it more expensive not cheaper. -- Whatsoever thy hand findeth to do, do it with all thy might |
#4 posted 06-23-2022 07:34 PM |
When a company like Lowes has a bundle of wood sitting on a shelf, still dripping moisture after being “kiln dried”, it’s probably prudent to apply a rot preventer/fungicide so your inventory doesn’t turn to trash before you can sell it. 8^) |
#5 posted 06-23-2022 08:08 PM |
I think they technically are purple and have heard it was a marketing angle to differentiate their product kiln dried southern yellow pine and heard they were precut for wall framing? Reported as stainable and paintable and they aren’t treated. I don’t think they sold very well and probably trying to get rid of them. At one time the Lowe’s website had photo showing the previous (purple color) and the new none dyed product. |
#6 posted 06-23-2022 08:14 PM |
Interesting question? Marketing: https://www.hansenpolebuildings.com/2013/01/2x4-studs/ Flame retardant: https://www.menards.com/main/building-materials/lumber-boards/dimensional-lumber/2-x-4-fire-retardant-interior/1141010/p-1444422266658.htm Mike Holmes: Pinkwood (a Canadian product out of western Canada) which is coated with a pink fire retardant coating designed to produce an endothermic (heat absorbing) reaction when exposed to flames. Watching to learn Lowes reason….. -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#7 posted 06-23-2022 09:02 PM |
I think they’re Spruce -- WAR IS PEACE. FREEDOM IS SLAVERY. IGNORANCE IS STRENGTH -- |
#8 posted 06-24-2022 01:21 AM |
I think it’s all got to do with your region. Here in the ATL , Lowes has pretty darn good framing lumber. Better and more consistent than pretty much all of the locally owned contractor suppliers. Some of which have been here over a hundred years. |
#9 posted 06-24-2022 02:30 AM |
Yeah, they’re definitely for framing. They have a weird length- 92 5/8 or something like that. -- Burn your fire for no witness |
#10 posted 06-24-2022 12:54 PM |
Pre-cuts: ‘By using pre-cut 92-5/8″ long studs the framed wall height ends up being 97-1/8″: (2) top plates for a thickness of 3″ Once typical 1/2″ drywall is installed to the ceiling the overall ceiling height drops from 97-1/8″ down to 96-5/8″.’ I had said Spruce, but I believe they are Doug fir which us east of the Mississippi dont see much of. Might look pink to some of us -- WAR IS PEACE. FREEDOM IS SLAVERY. IGNORANCE IS STRENGTH -- |
#11 posted 06-24-2022 01:16 PM |
8 ft is 96” |
#12 posted 06-24-2022 01:20 PM |
You walk around on the subfloor or carpet, hardwood, tile, etc,? -- WAR IS PEACE. FREEDOM IS SLAVERY. IGNORANCE IS STRENGTH -- |
#13 posted 06-24-2022 01:23 PM |
I am not an expert, but when you hang drywall, you usually put up the top piece horizontally first, so now the top 4’ of the wall is covered. Then you put the bottom piece on to cover the lower half. You want slightly more than 4’ of space on the bottom so that you can fit a wonderbar or something underneath the piece of drywall to lift it. |
#14 posted 06-24-2022 02:23 PM |
Understood, and al floor materials are different sizes, stained concrete being 0”, wood being various thicknesses, tiles being various thicknesses plus various thicknesses of thinset etc, so the math cannot be accurate. |
#15 posted 06-24-2022 02:24 PM |
This makes sense, just a buffer to allow the drywallers to work. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8201 |
34252 |
CNC Woodworking
387 |
Hand Tools
6789 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
