Forum topic by Mark Shultz | posted 06-22-2022 09:59 PM | 369 views | 0 times favorited | 12 replies | ![]() |
I need to cut the panels down for a new exterior door. These panels will sit on top of the spline shown in the first picture, and the edges will be covered with trim (a al a Norm Abrams video on exterior doors). The 2nd pic shows 2 panels which will be on the outside of the door. I need to cut 4 inches off the bottom or top of each (approx where the rulers are). which would you choose? same question for the other set of 2 panels, which is a more difficult question for myself. if i cut the bottom, it takes away from the large area of great figure and leaves a small area at the top corners. if i cut the top, it cuts all the figure off the top, which leaves the top a bit bear in comparison to the bottom. |
12 replies so far
#1 posted 06-22-2022 10:47 PM |
how bout 2’ off each end? |
#2 posted 06-22-2022 11:06 PM |
Looks like a significant bookmatching of the panels. Pic 2 shows the old guy with exaggerated eyebrows, sunken eyes, and on the left a nose. I’d retain as much of that as you could, so on them I’d cut off some forehead. I am losing track of tops and bottoms when going to the other side, but depending on the parts you like the most, keep them. From where I am looking it would be an easy choice. I would NOT cut off each end. Cut yourself a 4” piece the width of the panel, and use that as a sliding gauge to cover 4” at a time, and see what you want to keep. -- Think safe, be safe |
#3 posted 06-22-2022 11:48 PM |
I would NOT cut off each end. With capitol letters no less, well pardon me for offering an opinion. Won’t make that mistake again. Thanks for the insult. |
#4 posted 06-23-2022 12:28 AM |
My suggestion is the first pic 2 inches from both ends like common joe says. -- Aj |
#5 posted 06-23-2022 12:49 AM |
I would NOT cut off each end. You’ll get that from time-to-time around here. Actually, I agree with your suggestion for the boards in image three. Hard to say for sure just based on a photo, but that’s the way I’d go if I were doing it—2 inches off the top and two off the bottom. For the second image, I’d go 4” off the top. Actually, it’s a shame to have to take any off either board, but that’s what looks good to me. And REMEMBER†, this is a matter of opinion. If yours is different from mine, it doesn’t mean either one is wrong. It all comes down to how it looks to YOU‡. † Sorry, I couldn’t resist. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#6 posted 06-23-2022 12:54 AM |
Hard to tell, but I think I see the edge of a plywood board at the top of image two. That, and the grain looks like it’s two halves of a slip match that’s made up of book matched. That’s often how the veneer grain on a sheet of hardwood veneer plywood is laid out. Since it’s an exterior door, if that’s plywood, is it exterior grade? -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#7 posted 06-23-2022 12:58 AM |
4 off top -- WAR IS PEACE. FREEDOM IS SLAVERY. IGNORANCE IS STRENGTH -- |
#8 posted 06-23-2022 03:17 AM |
I used microsoft paint to hide a couple of inches at the tops and bottoms. I can’t see where it hurt the image any, but keen eye Steve may. |
#9 posted 06-23-2022 02:30 PM |
Take the 4” out of the middle. |
#10 posted 06-23-2022 03:02 PM |
I would trim the bottom in the upper pic, and in the lower one, take 1 1/2” off the bottom of the panel and the rest off the top. |
#11 posted 06-23-2022 03:38 PM |
good thoughts here. thanks folks. |
#12 posted 06-23-2022 08:49 PM |
Leave the top alone. The bottom won’t look significantly different where the top will and the top looks nice as is. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8201 |
34252 |
CNC Woodworking
387 |
Hand Tools
6789 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
