Forum topic by Watercolor | posted 05-25-2022 09:33 PM | 267 views | 0 times favorited | 7 replies | ![]() |
Just purchased a used but loved jwp208-1… currently looking for the knife gauge and bar but it seems i may have to order one. I find some sites say its discontinued and other have parts numbers that dont match. Any help is appreciated. I have contacted jet but havent heard back yet… Parts numbers according to the manual. JWP208-008 Thanks -- Its not what they call you, its what you answer to. |
7 replies so far
#1 posted 05-26-2022 01:23 AM |
currently looking for the knife gauge … – WatercolorJet parts, oh boy. - Need to stop using the marketing PN, and use the 6 digit product code. It’s a cluster flub if you don’t use the product code. They are changed with each new mfg, or major design change; but the bloody marketing PN stays same. Only with product code can you find the vintage of your machine, get right manual, and buy right parts. - IME – Jet tech service and parts department is PITA when it comes to getting information. I found out that calling them in person, gets the best response and answers. And if the first person you ask can’t help; tell them to find the product manager, or some old geezer tech/service person that knows the machines history. - I own a Jet JWP208 model planer, painted in antique Jet Blue. What I learned chasing parts for rebuild is all of the 20” Taiwan made four post planers are coming from same mfg, based on same design drawings. They use same; cutter heads, bearings, gear box components, and feed rollers. - Because of Jet parts challenges, I often use Grizzly planer parts when fixing Jet/PM planers. When I acquired my JWP208, Grizzly had the individual parts for 20” knife gauge in stock and I ordered a set. What arrived was same size as my 15” knife gauge, with same blade exposure. :-(0) If you check the dimensions on the 20” G0454Z knife gauge on Grizzly site, it approximates just over 14” long. By now, you are mumbling this Klutz has lost his mind; am I really suggesting to use a 15” knife gauge on 20” planer? Yes. And here is the 15” planer knife gauge from the Grizzly site (scale is 1”): If you want to pay twice as much as Grizzly for the Jet version 15” knife gauge, look up the JWP15HO-KG. PS – If you are new to planer setup, suggest you consider making a DIY rotocator. YMMV -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#2 posted 05-26-2022 01:58 AM |
Thank you! -- Its not what they call you, its what you answer to. |
#3 posted 05-26-2022 02:41 PM |
Looks like a great planer. I hope you find your gauge. Have you looked on eBay? -- James E McIntyre |
#4 posted 05-27-2022 01:44 AM |
I have been on ebay, no luck. I think captain has it right. Captain have you ever used the magnetic jig that have adjustable depth sets like these… -- Its not what they call you, its what you answer to. |
#5 posted 05-27-2022 01:49 AM |
Only down side js the manual doesn’t have a recommended height for the knife and my googlefoo isnt producing a number either. -- Its not what they call you, its what you answer to. |
#6 posted 05-27-2022 10:36 AM |
Never owned a planer magnetic jig, since Grizzly height jig is only $13-$15? You can make your own magnetic knife jig. Bob Vaughn has posted detailed instructions on VintageMachinery.org site, and has posted a couple of videos using his jigs. FWIW – With the magnetic jigs, don’t need to know the actual knife height, as you can measure/set the existing knife before removal :-(0) Recommended height of knives varies, based on who you ask? Regardless of jig being used, there can be a lot fine tuning the knife height. First time setting knives can take many hours, depending your level of perfection. The difference between just touching, and light scrape across TDC of knife is easily 0.005” difference. Even with an inspection mirror, it’s hard to see the difference; so I end up moving the gauge back and forth to feel the friction difference to enable +/-0.002 difference across the blade. I find the mfg recommendation of 0.005” max difference end to end to be too large. It is enough to make panel glue joints noticeably uneven, and some joints too loose. YMMV Will also learn that gib’s tend to move while tightening (will push jig up, or drop down); so best to snug the blade slightly too high; and use block of wood to tap the knife lower; then tighten down the gib bolts. This technique requires some practice, but I can change knives in ~hour. :) Cheers! -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#7 posted 05-27-2022 03:15 PM |
I watched the bob vaughn video, good stuff. I ordered the knife setting assembly you gave me a link to and i got the parts to build the rotacater. I appreciate all the help. -- Its not what they call you, its what you answer to. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8200 |
34251 |
CNC Woodworking
387 |
Hand Tools
6789 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
