My Delta 31-255X Drum Sander Is Sleeping…….
Forum topic by adot45 posted 05-25-2022 04:13 PM 393 views 0 times favorited 5 replies Add to Favorites Watch
View adot45's profile
adot45
705 posts in 2118 days
05-25-2022 04:13 PM
Went out to the shop early this morning to start sanding the rings I glued up yesterday. Got all the SS band clamps off.
Took them over to my drum sander, turned the dust collection on and flipped the drum sander on……nothing.
5 replies so far
View HokieKen's profile
HokieKen
22004 posts in 2632 days
#1 posted 05-25-2022 04:22 PM
No click from the switch or hum from the motor?
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
adot45
#2 posted 05-25-2022 04:46 PM
Hi Ken, I had a full paragraph that somehow disappeared and didn’t get posted, outlining my trouble shooting.
But in short, I applied power directly to the drum motor and it took off. Did the same for the conveyor motor and it took off. I ordered a new switch from Amazon and will be here tomorrow. Taking it apart now and taking lots of pictures.
HokieKen
#3 posted 05-25-2022 05:24 PM
Well, it’s too bad that the switch crapped out. But if something had to crap out, I’m glad it was the switch!
adot45
#4 posted 05-25-2022 05:37 PM
I just got it removed and it rattles…!…looking more and more like the switch was the culprit.
$7.80 Amazon prime, that’s the kind of maintenance I can handle! It’s been a good machine for me so no room to complain.
View Phil32's profile
Phil32
1802 posts in 1397 days
#5 posted 05-25-2022 05:47 PM
Some machine switches are susceptible to sawdust, especially toggle switches. Often you can disassemble the switch to remove or blow out the dust. Install a clear plastic flap under the upper mounting screw to reduce the access of sawdust through the toggle opening.
-- You know, this site doesn't require woodworking skills, but you should know how to write.
