Forum topic by Brett | posted 05-22-2022 04:37 PM | 316 views | 0 times favorited | 9 replies | ![]() |
I need to make a dowel just under 0.75” to fit into a 0.75” holdfast hole. A 9-mm roundover bit produces a dowel 0.709 inches in diameter, which is perfect for my holdfast holes. Does anyone make a 9-mm roundover bit with a 1/4-inch or 1/2-inch shank? (I’ve Googled, but had no success finding one.) -- More tools, fewer machines. |
9 replies so far
#1 posted 05-22-2022 04:47 PM |
Dont have a lathe to turn one? |
#2 posted 05-22-2022 04:54 PM |
If you don’t have a lathe, you could buy a 3/4” dowel and chuck pieces of it in the DP and sand it down. But it will probably be a little undersized anyway so might work just as you buy it. -- Our village hasn't lost it's idiot, he was elected to congress. |
#3 posted 05-22-2022 05:03 PM |
I’ve always just bought 3/4” dowels. They run small, and you need to use something to make them tight. I use the Paul Sellers method of inserting a bent lawn stake for marking sprinklers. |
#4 posted 05-22-2022 05:04 PM |
Do you know you can make a dowel on the table saw with a simple jig? If I only needed a couple I’d probably try scraping down off the shelf 3/4” dowel. |
#5 posted 05-22-2022 05:05 PM |
An older way for making (short) dowels was to drive a slightly over size piece of wood through a hole drilled in a thick steel plate. Taper the end of blank down to fit the whole and then pound it through the hole. -- Les B, Oregon |
#6 posted 05-22-2022 09:47 PM |
I do not have a lathe. -- More tools, fewer machines. |
#7 posted 05-22-2022 09:57 PM |
Would a 11/32” round over the fit too sloppy? (would require a router table w/fence) |
#8 posted 05-22-2022 10:17 PM |
https://www.lumberjocks.com/topics/314463 |
#9 posted 05-22-2022 10:56 PM |
What bit are you using to drill the holes? I just went out and measured with a micrometer. My off the shelf dowels are dead on 3/4” and all the holes drilled in my bench with an auger bit are 1/64th over. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
