Forum topic by kmetzger | posted 05-21-2022 05:46 PM | 380 views | 0 times favorited | 15 replies | ![]() |
What is the procedure for routing the inside edges of a handle for a serving tray using router table? I want to use a 1/4” roundover bit. -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
15 replies so far
#1 posted 05-21-2022 05:56 PM |
I always begin by drilling out the majority of the hand hole on the drill press, then I use a 1/4” masonite template with a pilot bearing on the router table to shape the hole to the desired form. |
#2 posted 05-21-2022 06:25 PM |
Thanks, Splinter. I don’t understand the part about the template with pilot bearing. -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#3 posted 05-21-2022 06:34 PM |
I don’t have any photos of the process being used on the tray project I posted, but my latest tissue box project shows the same process for the top. |
#4 posted 05-21-2022 06:47 PM |
Great info, Splinter. So you first used a straight bit and then a roundover? -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#5 posted 05-21-2022 06:53 PM |
I plan to clear out the openings on the drill press with a 1” drill bit. Just need to clean up the openings with a roundover. -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#6 posted 05-21-2022 06:53 PM |
Yes, the straight bit will get your hand hole identical to the shape of the template, then the round over will be able to follow the shape of the hole for a smooth contour. After drilling out the waste for the hole, I’ll use a jig saw or scroll saw to get as close to the outline as possible to make the initial routing easier. Using the top/bottom bearing bit allows you to always be cutting with the grain and helps to greatly reduce the sanding. |
#7 posted 05-21-2022 07:04 PM |
Excuse my ignorance. I don’t understand the template part. Do you tape the template to the workpiece? -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#8 posted 05-21-2022 07:14 PM |
make a side piece template from 9 mm ply to the exact finished shape and size. Drill or jig saw most of the scrap out. Then stick the template to your desired piece of wood, either with double sided tape, or even a couple of slim nails and use a flush trim router bit. This gives you the finished shape with straight sides, then use a bearing (or pilot) guided round over bit to soften all the edges. -- my projects can be seen at www.pbase.com/sunnybob |
#9 posted 05-21-2022 07:15 PM |
Kim, Here is a website that will help. https://www.woodmagazine.com/woodworking-plans/routing/templates-for-router-success This one is actually a better descriptor and shows both top and bottom bearing bits in use. https://www.woodmagazine.com/tool-reviews/routers/fast-easy-template-routing Regards, -- DaveS2, Canton GA aka pdwoodwerkz |
#10 posted 05-21-2022 08:09 PM |
I’m bamboozeled. The only way I see a 3 1/2 long x 1” template working is if I drilled out my opening maybe 3” long x 3/4 wide so I would have some surface to tape the template to over the opening. The template is still a mystery. Isn’t there a way to accomplish smoothing out the inside of the handle opening without a template? -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#11 posted 05-21-2022 08:44 PM |
Dave did a better job explaining 8^) I use double sided tape to hold the template to the piece. Your photo looks like the handle is just a straight slot, no curve. That’s fine, you just need to drill the ends like you suggest with a 3/4” bit, then using a jig saw or other cutter, join the two holes to form your slot. You can then clean up the slot with a rasp. A template lets you use the router for the clean up so it is faster. Once you have your slots finished, you can then use your 1/4” round over bit with its pilot bearing in the router table. The bearing will ride along the walls of the slot you drilled/rasped. I posted a project of serving trays that show the finger slots I cut with a curved router template. I didn’t show the template but on the third photo you can see the rounded edges. |
#12 posted 05-21-2022 08:55 PM |
Thanks, Splinter. That’s the way I’ll go. Any advice on feed direction? -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
#13 posted 05-21-2022 09:02 PM |
You can only go one way with the round over. Since it is in a table, you need to work the bit around CCW in the slot. Save one last cut as a skim cut, that is raise the bit maybe a 1/32” or less. This lets you remove most of the burns and should leave the cleanest edge. End grain routing around those curves at the ends of the slot always seem to burn a bit and require some finger flexing sanding action (the part of woodworking I detest the most!) |
#14 posted 05-22-2022 11:10 PM |
Many ways to do this. I would draw out the handle slot with pencil or pen, drill out a 1/2” hole inside the handle slot, use a jig saw to cut inside the lines, then use a spindle sander with an 1/2” or 3/4” sanding drum to sneak up to the pattern drawn with pencil, then use a router bit (1/4” round-over with bearing) to soften the edges of the handle. |
#15 posted 05-22-2022 11:14 PM |
Thank you, sounds like a plan. -- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25 |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
