Forum topic by Karda | posted 05-20-2022 03:57 PM | 502 views | 0 times favorited | 12 replies | ![]() |
12 replies so far
#1 posted 05-20-2022 04:15 PM |
It probably will work just fine. Pretty simple jig. Personally I just dropped an extra 25 and got the real deal. Maybe I flushed money down the drain but I find it much more frustrating and costly having to fix something, modify something, have to rebuy a product, or always fidget with a tool to use it. |
#2 posted 05-20-2022 04:16 PM |
I can’t afford 70 dollars for a new one |
#3 posted 05-20-2022 04:23 PM |
I don’t know where I saw the post, Here or probably on a Facebook woodturning site. But It seems the bolt was short. Or something like that. -- John |
#4 posted 05-20-2022 04:52 PM |
I think I will stick with what I know. From what I have seen the advantage of tne vari grind is changing and I don’t do that |
#5 posted 05-20-2022 04:57 PM |
This appears to just be the attachment and does not include the base. Go to the Vevor web site and check out all their tools. The price seems to be the same as on ebay. Ii appeas with the base it is in the $70+ price range. -- Les B, Oregon |
#6 posted 05-20-2022 04:59 PM |
I have the bases and the basket |
#7 posted 05-20-2022 06:21 PM |
I do like to be frugal myself. I have purchased knock-offs or similar of the real deals of different tools in the past. Thinking (I can upgrade later) it’ll save me some cash for now. Only be out a small amount if it didn’t perform the way I expected. Only been disappointed a couple times. Usually the items are made of cheaper materials and might need a modification, like mentioned above. Some of the inexpensive tool knock-offs I have worked out fine. Price seems good for what you get. Seller has a 96.9% favorable feedback, which is good. Take a good look at it and compare the differences of the tightening method to lock in the turning tool, before purchase. |
#8 posted 05-20-2022 08:06 PM |
ok |
#9 posted 05-20-2022 09:00 PM |
One thing that appears to be different is the bolt head that locks the gouge into the jig. The Wolverine has a rubber pad there and it may also have a socket that prevents the head from turning when you tighten it. A spinning head may make it slightly more difficult to prevent the gouge for moving as you lock it down and the pad keeps if from denting or marring the gouge. They appear to have added a piece of sheet metal so maybe that is not a big deal? But when their pictures do not even show the correct way to use the jig, that makes me wonder if they ever tried it to see if it works. One of the pictures shows a bowl gouge mounted sideways and another bench chisel clamped in sideways and grinding blunt, curved tip. Really? -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#10 posted 05-20-2022 11:07 PM |
yea I kinda wondered what a chisel with that grind would be used for |
#11 posted 05-21-2022 10:51 AM |
I’m thinking the vari-grind might be available for closer to $52 with a little shopping (try Hartville or Lee Valley). May not market if more affordable, but helps. Also Craft Supplies USA just recently released their version of a sharpening system ( got a email yesterday)—the gouge jig is $40, and the fine print says it’s compatible with Wolverine. They also state that the rest of components are not compatible. Might be worth checking. |
#12 posted 05-21-2022 03:21 PM |
Now that’s funny. I had not seen those photos of a chisel mounted in the jig. I am concerned with the Lee Valley description on the jig, It says it will accept a tool up to 3/4”. Craft supplies is at $60 and tend to ship free sometimes. I can go on and on, lol. I don’t shop Ebay much, but.. There is one here listed at $60 or best offer. -- John |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8200 |
34251 |
CNC Woodworking
387 |
Hand Tools
6788 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
