Forum topic by bp2878 | posted 05-19-2022 03:31 PM | 488 views | 0 times favorited | 5 replies | ![]() |
Made some signs out of rough cut Hickory. client was them to look natural, no finish at all on these. Want’s the lettering painted. My plan is to shellac the lettering prior to painting to prevent bleeding. I’d like to put nothing on the rest of the signs. Will this work out? Or do I need to put a flat WB poly on the signs. They will be indoors. Brand new to sign making.. TIA |
5 replies so far
#1 posted 05-19-2022 03:39 PM |
#2 posted 05-19-2022 04:52 PM |
To get it painted, I might consider using some liquid masking then exacto out the engraving. Then spray shellac to seal followed by paint. When I’ve laser engraved things, I’ll cover the surface with tape, then engrave through the tape. Makes painting the engravings pretty easy as the tape perfectly matches the lines. Never tried it, but I wonder if you could liquid mask the surface of the board prior to machining to make it easier. If they’re indoors, no need to put a finish on the wood. But that being said, I think something an oil finish of some sort (Tung Oil, BLO, Danish Oil, Rubio Monocoat, Osmo) would provide a nice look (that remains natural). |
#3 posted 05-20-2022 02:17 PM |
Ive never used the liquid mask but I will look into it. I think the rubio would be a pain to get into and out of all the saw marks but I will definately try the blo and tung oil to see how it looks on some scrap. Thanks for the input. |
#4 posted 05-20-2022 04:40 PM |
Don’t think you’d have that issue with Rubio. I’d use it. It isn’t a stain or finish in the traditional sense as it bonds to the wood vs sitting on the surface. Just wipe it off. Rubio says “you can’t wipe off too much”. -- Andy - Seattle USA |
#5 posted 05-21-2022 06:47 AM |
Hickory is rather dense wood.. I’d test the type of paint you plan on using, on a scrap piece of hickory, before the applying it to the final piece. Depends on the type of paint you use. Some paints won’t bleed into the wood. I have used the Testors brand (model car paints for plastic cars) on wood, without taping off. And not experienced bleeding or leaching out. Results may vary of coarse. So test on scrap pieces wood. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8200 |
34251 |
CNC Woodworking
387 |
Hand Tools
6788 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
