epoxy
« back to Woodturning forum
Forum topic by Karda posted 05-17-2022 08:24 PM 333 views 0 times favorited 4 replies Add to Favorites Watch
View Karda's profile
Karda
3422 posts in 2043 days
05-17-2022 08:24 PM
i have bowl gouge that is wearing out, the handle is a nice one I made from some walnut I had. My problem is I epoxied the gouge into the handle like I never wanted it to come out, is there any way to break the epoxy bond. I don’t want to ruin the handle thanks
View splintergroup's profile
splintergroup
7112 posts in 2712 days
#1 posted 05-17-2022 08:36 PM
Heat is the enemy of epoxy.
If you don’t care about the steel, I’d try heating it up with a propane torch until you see the epoxy starting to soften. Give it some twists and pulls (with the steel in a metal vice) and see if it can be worked loose.
Karda
#2 posted 05-18-2022 03:02 AM
thanks I’ll try that
View HokieKen's profile
HokieKen
21983 posts in 2628 days
#3 posted 05-18-2022 12:07 PM
Yep, what splintergroup said. Heat will soften the epoxy heat the shaft with a torch until it will come out.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View OSU55's profile
OSU55
3050 posts in 3479 days
#4 posted 05-18-2022 08:19 PM
Even if you care about the steel, heat it up to break the epoxy bond. Give a little time for the heat to travel down the steel into the handle , heat for a min or so , wait a min, heat some more, wait, etc. put the tool end in a vice. Use a strap wrench on the handle, check between heatings if the handle will turn. Wont get hot enough to anneal the steel.
