I find a box fan and wicking shirts do the trick for me. I aim the box fan so I am typically getting hit in the back as about the largest area for evaporation, hits the back of my neck and shaved head. Plus no dust and crap blown in your face. Typically wear a light weight nylon hiking pant also.
A large Yeti style cup also is a must in my book. Can keep tea or water cool in even very hot weather to keep hydrated and doesn't sweat.
Another vote for a mini-split. Just understand they do NOT de-humidify much. Coils run at or above dew point which is one reason they get the very high SEER ratings. You may need a de-humidifier as well. Seems stupid to me as we would use less energy if we had a 16 SEER that ran 5 degrees cooler so we don't need a dehumidifier!
Of course insulation is key, even if you just open up and use fans.
I live in So Cal. During a few weeks of summer the only way to stay cool is to work at night or early morning. Beach during the day then shop at night.
Pfft. Please stop propagating this misnomer debunked here and here
The ability of a mini-split to dehumidify depends on what you buy.
Buy cheap junk, have improper gas levels/pressures, and/or unit with too much capacity for room size; then de-humidification is subpar.
There are differences in HVAC optimizations made for different climate zones. Most people don't know they need a unit rated for their location. This makes buying a random Mini-Split online somewhat like gambling at Black Jack tables.
Complaints about humidity removal are perfect example why is it best to let a professional recommend the size, brand's/PN's optimized for local use, and install any HVAC unit.
I live in GA and have had 2 small shops before moving the shop to the house. Insulation is a must. The ability to have a quick cool down from a closed up shops 100 plus temperatures is a big plus. Quick cool down meaning an open door on one end and a high cfm fan on the other. I used a HF 8" portable Ventilator which doubled for exhaust when spraying finishes. My shops were small so the correct size widow unit had the shop cooled down enough to start fairly quickly.With the size of your shop window units would not be the best choice. Check into the mini split units. Pick a quality unit that is rated a little bigger than the space your cooling.
North of you so some cooler in SW Ohio. I'm 32×48 all on a thick concrete pad, which I call my cool sink.
I'm well insulated with 2×4 framed walls fully stuffed, and R 56 in the attic, with well sealed doors and windows.
Going out in the early Am, I need a light jacket, because all that concrete gets cool overnight.
I keep it closed off, and only open the man door going in, or out. In the past I used to have to exit about 3:30PM, now I've hung 2, 6' diameter fans in the back, and flipping them on I can hang till 7PM or so when it's time to eat, going in then anyhow.
Before I spent a few thou on cooling a barn, I'd see what Ma Nature would do for you.
Don't get a unit rated for more than your space. That leads directly to not removing humidity. On the hottest day, the unit should run most of the time. Under size slightly for the best dehumidification.
If you have to add something, the mini split would be my first choice….plus it will provide heat when you need it. Remember, while it may be warm enough for you in the winter you may still need a little more to allow finishes to dry/cure, or glue to set up.
As said above, the unit must be sized to run long enough to pull the moisture out. Sticking in an oversized unit will turn your shop into a mold spore.
I have an 18K BTU mini split in a 25×25 well insulated space with 10 foot ceiling and it works great. Obviously a 25×40 foot would require much larger unit.
Air conditioning can be expensive so I would get a big box fan and keep a continuous air flow going through the shop. It will still feel warm, but the continuous air flow will make it more comfortable. Position the fan to draw air from the cool side of the shop and exhaust at the sunny side of the shop.
My mini cools my 16×24 shop with a 10' ceiling for 25 cents a day I have the hour meter and the kilowatt hour meter on the unit to record costs. I log it almost daily. So a 24×48 should cost less than $1 a day with a 27 rated unit.
My mini cools my 16×24 shop with a 10 ceiling for 25 cents a day I have the hour meter and the kilowatt hour meter on the unit to record costs. I log it almost daily. So a 24×48 should cost less than $1 a day with a 27 rated unit.
Mine is from LG. I can't get the model right now, but it was the smallest made at the time. If your shop is 24×48 you will need at least three times larger. You need to size it for your area AND your area. Illinois is different than Georgia. I bought from Supply House.com, but there are unlimited places to buy. I have 12" of fiberglass in the ceiling, and 6" of fiberglass in the walls. So get it sized correctly, pick the highest efficiency rating within your budget, and go for it. You may want 2 or 3 indoor units that run off one condenser outside to spread your cool around.
FYI, its simple to size a unit go on line to one of the on line sellers and they will have a caculator to assist you in sizing. just be truthful on the imput of your structure and detail info.
rule of thumb my ac guy shared is average is about 400 sq ft per ton, based on modern day insulation requirements, now if you have the new updated insulation code and meet it, you are much better off.
either way, i went basically this route on sizing, and since i have two 5 ft ceiling fans up in trusses to add air flow, its great, we are having 100 degree days now and it easily keeps shop cool, once we hit july see how well it works.
good luck
rj in az
Mine is from LG. I can t get the model right now, but it was the smallest made at the time. If your shop is 24×48 you will need at least three times larger. You need to size it for your area AND your area. Illinois is different than Georgia. I bought from Supply House.com, but there are unlimited places to buy. I have 12" of fiberglass in the ceiling, and 6" of fiberglass in the walls. So get it sized correctly, pick the highest efficiency rating within your budget, and go for it. You may want 2 or 3 indoor units that run off one condenser outside to spread your cool around.
To my mind insulation is key. Walls and ceiling at 30+ and it will be a huge plus. I live in Oregon not Georgia but it gets hot (100F) occasionally in the summer and snows in the winter. The shop ranges from 60 to 70 year round. Only a small heater. No cooling.
Something to consider is dividing the shop so not as much space is conditioned - just depends on how you use it. Price out a regular heat pump as well as mini splits. You would gain better air distribution with simple duct work. A mini split will need some other air movers to distribute properly - need to evaluate total installed cost.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
