Forum topic by jarheaddoc | posted 05-16-2022 07:49 PM | 454 views | 0 times favorited | 4 replies | ![]() |
I am looking for ideas on how to build a coping sled. I make angled cope cuts on arches and consistently tear off the point of the radius (where the rail and stile come together). It’s not just the angle that I have trouble with, the piece is also wide, like 8 inches rough, and it doesn’t seem like commercially available jigs are set up to handle that width. I would like to use either phenolic or aluminum for the base. Thanks for your input. |
#1 posted 05-16-2022 10:55 PM |
You mean like the arched stile on the top of a raised panel door? Maybe start with how you are doing it now will get some ideas for how to deal with the tear out. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#2 posted 05-17-2022 12:41 AM |
im sure you can make one.i agree about the sleds,i have the wopodpeckers sled,it’s well made and works great but wont except wood that wide.mine will go to 5-1/2”.use that as a model and just make a bigger one. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#3 posted 05-17-2022 12:48 AM |
If you are building frame an panel doors, what about purchasing a router bit set designed for them. They will handle the arched top also. You would also need a backer block to eliminate the tearout at the end of the cross grain cut. -- Eric, building the dream. the "Loft" |
#4 posted 05-17-2022 01:15 AM |
I had to build one for coping rails on residential doors, which can be up to 11 inches or so. All you need is a solid base like 1/2” MDF, a fence that’s square to the edge and a couple of toggle clamps for holding down the work. The key is to keep the rail square to the cut and there are numerous ways to accomplish that. In a pinch, I’ve even used a square piece of 3/4” MDF as a guide. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
