Forum topic by Bearpaw | posted 05-16-2022 04:57 PM | 561 views | 0 times favorited | 19 replies | ![]() |
Topic tags/keywords: jig tip question trick Does anyone have an idea how to use this bit freehand instead of in a router table? Some kind of jig, maybe. -- "When we build, let us think we build forever." John Ruskin |
19 replies so far
#1 posted 05-16-2022 05:15 PM |
Do you not have a router table? |
#2 posted 05-16-2022 05:22 PM |
The locking miter bit is primarily used with a router table. You sorta need the fence on the table to help with the set-up. It also be can be used with a horizontal router table also. You could try it free hand. But then don’t expect to have any sorta of a good match. |
#3 posted 05-16-2022 05:53 PM |
The lock miter bit could be a handful to use freehand unless you have some sort of jig to hold/guide the router. I’ve never seen any jigs for free-hand use of this bit. I’ve only used a router table with a fence for this bit. |
#4 posted 05-16-2022 06:06 PM |
Are you talking the drawer lock miter bit? You cannot use it freehand. It’s hard enough to match up the joint with a router table and a fence, the line of cut and the depth of cut have to be PERFECTLY matched. -- NorthWoodsMan |
#5 posted 05-16-2022 06:33 PM |
+1 Are you talking the drawer lock miter bit? You cannot use it freehand. It s hard enough to match up the joint with a router table and a fence, the line of cut and the depth of cut have to be PERFECTLY matched. – northwoodsman -- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 05-16-2022 07:33 PM |
I’d bet you could …with a considerable amount of effort and trial and error use a lock miter but in a hand held router, but they can be frustrating on a table (which they are made for); it would test the patience of Job to use it free hand (says me, who has not tried one free hand). -- Our village hasn't lost it's idiot, he was elected to congress. |
#7 posted 05-16-2022 07:38 PM |
Yep, definately want a table to get a good joint, You can use a hand router with an edge guide but only with pure luck will you get anything of reasonable quality. |
#8 posted 05-16-2022 07:41 PM |
Why would you even try? You are almost guaranteed a failure. There are most likely many better suited solutions for this joint that are not only safer but are going to yield better results. I certainly wouldn’t encourage someone to go down this path or provide hope that it’s a possible solution. -- NorthWoodsMan |
#9 posted 05-16-2022 11:28 PM |
That type of bit has one piece run flat, the mate, on edge. You can’t get the vertical cut to work with a handheld. Hell, it’s tough enough with a fence. -- The hump with the stump and the pump! |
#10 posted 05-16-2022 11:33 PM |
Even the thought of using it freehand is scary… |
#11 posted 05-16-2022 11:48 PM |
I would never use a bit that big freehand, but it would help to cut off a lot of the waste first at the table saw. -- Bill M. "People change, walnut doesn't" by Gene. |
#12 posted 05-17-2022 12:35 AM |
i agree with whats been said.that bit is not meant for freehand work.you’ll never get a perfect match,and thats what you want ? -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#13 posted 05-17-2022 12:44 AM |
I use a jig on the router table and its still tricky to get right. There’s nothing to stop the board from being pulled into the bit using it freehand. |
#14 posted 05-17-2022 12:47 AM |
I’m sure you could use it with a fence attached to a freehand router. But I would expect it’s considerably easier to build a router table and then use that. -- Alan in Wisconsin |
#15 posted 05-17-2022 01:02 AM |
Bearpaw – this bit is designed to be used in a router table with a fence. If nothing else, for safety sake please do not attempt to use it in a hand held router. -- NorthWoodsMan |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
