Forum topic by Karda | posted 05-16-2022 04:27 AM | 543 views | 0 times favorited | 16 replies | ![]() |
Hi I have some kiltz that is getting old, can I use it for sealing end grain, it is an alcohol based stain sealer similar to Bin primer |
16 replies so far
#1 posted 05-16-2022 09:00 AM |
AFAIK, the original Kilz was oil based, and then they came out with a VOC friendly water based formula, which is basically the same as latex. Either should be fine for sealing end grain. I don’t think I’ve ever seen one that was alcohol based, so that might be a different animal than what I’m thinking of. I just use old latex paint, and prefer white so I can write on the piece the type of wood and date harvested with a black marker. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 05-16-2022 12:51 PM |
I’ve used it with good results. -- Bondo Gaposis |
#3 posted 05-16-2022 03:24 PM |
thanks I must have been mistaken, I just assumed. I figured I might as well used it it is just going bad |
#4 posted 05-16-2022 06:09 PM |
i tried using left over ext, latex paint, but alas, here in desert where no humidity most of year, it was marginal. still a lot of major cracking and shrinkage, but mother nature will provide other options on pcs, later on. -- Living the dream |
#5 posted 05-16-2022 07:13 PM |
IME – The wood surfaces dry so fast in Arizona, you have to paint the ends immediately after felling, or they have already cracked a few hours later. Also, latex does not seal AZ DRY end grain well. The wood absorbs the water in latex, and prevents significant sealing. I use oil based primer, random left over enamel, or thinned down ‘old’ polyurethane; when I need to seal end grain. The oil base takes longer to dry, absorbs further into wood, and appears to seal better. One of my Sawyer’s swears; it’s Anchorseal (oil base solvent emulsion and wax), or nothing; as all other solutions behave like no sealer was used in our single digit humidity. When I first learned to buck/saw logs as kid on giant saw driven by wide belt and PTO on tractor; farmer that owned the saw, used to heat linseed oil and paraffin wax to seal ends of large beams. Normal lumber slabs were never sealed.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 05-16-2022 08:18 PM |
a lot of what is for sale is convenience |
#7 posted 05-16-2022 10:06 PM |
I have never had luck using latex or oil based paints to seal end grain so that it doesn’t crack. No mater which one or how much I apply, the ends always crack within a day or two. The only thing that works for me, and it works very well, is Anchorseal. I have tested latex paint and Anchorseal applied at the same time immediately after cutting on opposite sides of the same cut and the painted one cracked overnight while the Anchorseal one was still uncracked several months later. BTW, the Rockler version called Green Wood End Sealer is exactly the same same stuff as Anchorseal but is about half the price. If you pull up the SDS from Rockler on their Green wood end sealer, they give you the Anchorseal SDS and it looks and performs identically to Anchorseal. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#8 posted 05-17-2022 01:55 AM |
FYI – Kilz does not have an alcohol / shellac based primer similar to BIN. |
#9 posted 05-17-2022 04:35 AM |
Like CaptainKlutz states getting the wood sealed fast is key in Arizona. I have had a lot of success with Old Latex. Flooring latex is the best result. I have not used Achol stain sealer similar to Bin primer and did not know they made it with alcohol. Primer seals but does not coat over preventing air. Anytime I tried primer it failed. Latex enamel has worked well. I managed to get eucalyptus to dry without cracking or warping using two or three coats of old latex paint and some other tricks. Just primer never. You can’t get a thick enough coat to prevent air movement. |
#10 posted 05-17-2022 01:50 PM |
I use PVA drywall primer … about $12 a gallon at most home centers. I apply 2 coats and get excellent results. The key is PVA … Polyvinyl Acetates. PVA is used in many wood glues, and is a clear, odorless, rubbery polymer that helps to seal up the wood pores. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#11 posted 05-17-2022 03:46 PM |
ok thanks |
#12 posted 05-18-2022 08:14 PM |
I use pva glue, usually TB2, no thinning, brush on heavy coat. |
#13 posted 05-18-2022 09:37 PM |
thats what I was using before I got the end grain sealer I am almost out of. might just go back to that |
#14 posted 05-18-2022 10:29 PM |
The alcohol based primer/sealer is rated as a vapor barrier for homes like mine that so not have a vapor barrier. It wasn’t a thing in 1915. But, yes, if what you have is the alcohol base primer, it will work. It is very thin. I buy anchor seal direct from the manufacturer in 5 gallon buckets. I will check the rockler price to compare. Thanks. |
#15 posted 05-20-2022 02:09 AM |
I have found here in the Vegas desert, that tite bond 2 wood glue makes a great end grain sealer. and I buy a gallon of it at a time anyhow. So I always have it on hand. The logs pictured are about a month old. I left them 2 to 3 feet long. I have had better success not cutting them into a usable size till I need them. This tree fell over in a wind storm. Turns out it was dying. Base of the tree was heavily spalted. -- John |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
