Forum topic by TEK73 | posted 05-15-2022 07:19 PM | 510 views | 0 times favorited | 9 replies | ![]() |
Topic tags/keywords: bed joining question Hi Anyone know what kind of joinery that could/should be used to build this bed? -- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin |
9 replies so far
#1 posted 05-15-2022 07:40 PM |
Dowelmax |
#2 posted 05-15-2022 08:07 PM |
For the foot board and head board you want them to be solid. For the sides they need to be knock down. The bed needs to come apart so you can move it. Rockler sells bed hardware. -- NorthWoodsMan |
#3 posted 05-15-2022 08:13 PM |
yeah, you’re not moving that in one piece. Side rails need to come offand |
#4 posted 05-15-2022 09:00 PM |
I’ve built a couple bed frames. The customer said to make them solid and that they were going to be permanent, so, I used screws to connect the side rails. The correct way, as mentioned above, is where you can disconnect the Rails if you ever move room. Hardware for attaching the side rails with brackets; From Rockler.com https://www.rockler.com/5-surface-mounted-bed-rail-brackets From Woodcraft.com https://www.woodcraft.com/products/tapered-connectors-4-pair |
#5 posted 05-15-2022 09:01 PM |
https://www.rockler.com/locking-safety-bed-rail-brackets yw :<)))))))))) -- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<)) |
#6 posted 05-15-2022 09:05 PM |
As state above, the legs and foot board would become one piece by the use of mortise & tenon, dowels, loose tenons, etc. However, the foot board is pretty wide and may be subject to seasonal expansion and contraction. If you don’t know already, one way to deal with that is to use a mortise & tenon, but glue it only about 1/2 it’s length. Do a little research on the subject if you don’t know about it. |
#7 posted 05-16-2022 06:53 AM |
Thanks, I think I got it now. I was stuck in thinking the legs should be “free” and both the sidebords and the footboard should be mounted afterwards. -- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin |
#8 posted 05-25-2022 05:10 PM |
If you are married, or living with your significant other, my suggestion is that you follow the guidelines offered here regarding bed hardware that allows the removal of the rails. If you’re single-you can ignore all this advice-LOL!! |
#9 posted 05-27-2022 10:30 AM |
Wife, fore kids, one dog and two cats… I have been wondering if I should just use “simple” hardware like this: Or more traditional joinery supported by hardware, like this: I’ll think I go for the latter, as I think it will be more fun to build. The first version for sure will be easier, but it feels a bit like cheeting ;-) I’m going to create a sketchup model of the bed first, will probably post it here when I’m done… -- It’s good to have an end to journey toward; but it is the journey that matters, in the end. - Ursula K. LeGuin |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3019 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8205 |
34258 |
CNC Woodworking
387 |
Hand Tools
6790 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
