Forum topic by kuramba | posted 05-07-2022 11:43 PM | 669 views | 0 times favorited | 17 replies | ![]() |
Hello, i have 7 jatoba 4/4 boards that i need to glue up. I thought my Makita track saw would do the trick but no such luck. The track is too short and repositioning it does not work |
17 replies so far
#1 posted 05-07-2022 11:47 PM |
It is a little too far for me to drive for a beer. Have any hand planes? -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#2 posted 05-08-2022 12:00 AM |
I do but not here :-( I am helping my son to make a countertop. |
#3 posted 05-08-2022 12:12 AM |
Other than buying another section of track, the only other thing I can think of is to make or buy a simple fence style guide or straight edge. I have read that the composite trim is usually pretty darn straight and smooth so if you can find a straight piece long enough for your cut, you can glue it to a piece of 1/4” MDF or hardboard and make a quick and dirty saw guide. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#4 posted 05-08-2022 02:18 AM |
Maybe there is some woodworking shop where kne can rent tools and space? |
#5 posted 05-08-2022 04:02 AM |
Sometimes wood suppliers have a milling service and the will joint the edges for a small fee. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#6 posted 05-08-2022 04:56 AM |
Track saws don’t need the track, it is convenient, but what Nathan described above will work fine, is cheap, and easy. If you need a Jointer, TS, or other tool in Portland, I’d suggest changing your title to “Need help jointing boards in Portland” or something that steers the conversation automatically to Portland. -- Think safe, be safe |
#7 posted 05-08-2022 05:31 AM |
Thanks for the suggestion to change the title. |
#8 posted 05-08-2022 11:28 AM |
I haven’t tried to make a panel since I sold my jointer so I will need to try one with a hand plane. So I am a +1 for hand plane but it would be a difficult first time learning experience. With a lot of practice I am just now getting proficient at making S4S boards. I am sure edge jointing will be a whole new challenge but like above suggested method making two boards have a mirror edge where each matches the other is the way to go if perfect is not within reach. |
#9 posted 05-08-2022 03:18 PM |
Have you worked with Creative Woodworking NW Inc before? Scrolling through their pics on Google Maps, it appears they have a nice jointer in shop. Believe they will work with you by the hour… Website isn’t very helpful, but give them a call on Monday. |
#10 posted 05-08-2022 10:04 PM |
Seeing full width curls coming off the plane is a pretty good indication you are moving across a flat piece of edge, if the square shows it to be square you are done. The hardest part is going to be setting depth of the cut, and that ain’t so hard. It’s just tricky work if the edge starts as rough, a lot of passes until you get flat and full width. Mostly flat to start and no biggie. -- Think safe, be safe |
#11 posted 05-08-2022 11:36 PM |
You can joint with a router table. It’s not that hard to build the fence for it out of something like MDF. Arguably the fence needs to be straight so you need a way to make it so without a jointer. I’m not trying to make it seem difficult. Most of us with a lot of tools here probably started off pushing the boundaries with just a few. |
#12 posted 05-09-2022 05:06 AM |
I live in Hillsboro and have a jet 6” jointer as well as Makita guide rails from 39” to 118”. I would be unable to support early in the week due to work obligations but may be able to work something out for later in the week. Feel free to message. George |
#13 posted 05-10-2022 07:39 AM |
read all the comments in this thread: https://www.lumberjocks.com/topics/317909 Use the suriawase technique. -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn (and that is nice) |
#14 posted 05-23-2022 01:34 AM |
Thank you George, Hillsboro is pretty far from where I am especially taking into account that the lumber I need to join is pretty long – over 10’ and I had difficulty bringing it home from a pretty close by lumberyard. So… Makita did not cut in. The wood is Jatoba which the tracksaw only managed to burn with frequent stopping. So I ended up using a skillsaw. But it was later. I found some “straight enough” long board and used a router to get the first straight edge. This attempt failed miserably. The panel I glued up exploded when I took the clamps off. After many tries and errors I finally found a solution that gave me a perfect straight edge, which I used to joint the rest of the board. (remember I was far away from my shop and did not have access to my own tools) I found a few laminate flooring planks that happen to perfectly straight but too short. I connected three of them together and aligned one to the other using one more plank. Then clamped it down to the board and used a hand held router to trim the edge. Once I had one straight edge I used it to process the rest of the boards. The results appeared to be pretty good. I managed to build somehow complicated set of kitchen long countertops using only a skillsaw and a router. |
#15 posted 05-23-2022 01:38 AM |
Have you contacted Woodcrafters. They got a store at 6th and Davis, 503-231-0226. They might be able to help or at least point you in the right direction. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2085 |
Finishing
6732 |
8201 |
34252 |
CNC Woodworking
387 |
Hand Tools
6789 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
