How Did You Design the Dust Collection for Your Miter Saw Station?
Forum topic by NohoGerry posted 05-07-2022 07:54 PM 1477 views 0 times favorited 27 replies Add to Favorites Watch
View NohoGerry's profile
NohoGerry
65 posts in 203 days
05-07-2022 07:54 PM
Guys,
The next project in my new shop to get it organized is to build a miter saw station. My design will include base cabinets for storage drawers and a dust collection system that will hook into my future Oneida Super Cell (will be getting it this summer).
I know that miter saws are notorious for being a challenge to set up dust collection, but i’ve seen various designs that incorporate large hoods over and behind the saw that lead to a dust vent below the table with a 4 inch outlet (that’s how I plan to connect it to the Super Cell system).
Is that how you built your dust collector fixture for the miter saw?
Do you have a different design?
My Hitachi 10” SCMS also has a 2 inch port behind the blade-should I consider an additional hose to the hood? Or just let the hood take care of all the dust?
Thanks in advance for the help-if you can supply pictures of your setup it would be much appreciated.
Gerry
27 replies so far
View Vandon's profile
Vandon
106 posts in 888 days
#1 posted 05-08-2022 02:17 AM
Wheels. I use wheels. My garage is my shop. Every tool I have is on wheels. I wheel my miter saw outside and shoot the sawdust into the bushes.
View ibewjon's profile
ibewjon
3026 posts in 4286 days
#2 posted 05-08-2022 02:49 AM
Same here. Although I have a good dust collection system, I don’t use the miter saw much, so I just roll it outside. Even in winter.
View controlfreak's profile
controlfreak
3871 posts in 1094 days
#3 posted 05-08-2022 11:49 AM
I got rid of that tool, problem solved. Dirty and a space hog, sorry I am no help on this subject.
7503 posts in 3986 days
#4 posted 05-08-2022 12:56 PM
After 4 designs (and failures) I gave up. There’s no miter saw in my shop anymore, it sits in storage waiting for home improvement projects.
View Brawler's profile
Brawler
227 posts in 1323 days
#5 posted 05-08-2022 01:15 PM
I found that about 98% of what I use for the mitersaw for is to make boards to length (small cuts). The DC port on my Hatachi 12” gets about half of the dust, that is good enough for me. I just pull the hose off the DC port and vacuum the remainder when finished.
-- Daniel, Pontiac, MI
View gbarnas's profile
gbarnas
123 posts in 275 days
#6 posted 05-08-2022 02:50 PM
I’m still fitting the DC piping and miter saw in the new shop, but my miter saw sits between two cabinets. There’s a Masonite panel between the cabinets that’s waxed and grounded so any dust falls to the saw shelf.
I place a blast gate above the station, then a 4/4/2 WYE to connect a hose to the dust port on the saw. The 4” continues down to the base, where it passed through the base. Under the miter saw base is a small channel made from x2s. A piece of Masonite covers this channel, and I have a 2 slots cut across the base into the channel. The dust port collects a fair amount (Also have the Hitachi 12” saw), the rest sprays onto the back panel and falls to the base, where its sucked through the slots. I keep a whisk broom to brush off the saw and base while the DC is running to clean up the little bit that’s left.
Waxing and grounding the back panel minimizes what dust sticks to the panel, and a tap with my fist knocks anything that does stick off and down to the collection slot.
-- Glenn, Jersey Shore, NJ
View Knockonit's profile
Knockonit
1289 posts in 1695 days
#7 posted 05-08-2022 04:20 PM
i attempted several methods, none were absolutely the ’’cats ,meow’’ so i gave up, and now that i’ve given it some thought, i may get relegated to the exterior patio, and keep covered till used, not like i use it every day.
once i get the sliding table saw up and running, well actually placed so i can make it work in my too small built shop, dang it knew i shouldnt have let her convince me to chop off 10 ft of it, lol
oh well.
happy days are here again, retirement around the corner.
Rj in az
-- Living the dream
View JackDuren's profile
JackDuren
1859 posts in 2452 days
#8 posted 05-08-2022 04:33 PM
At the furniture company we had a 4” come down and the dust went begging the miter saw. Worked okay and at he end of the day I just pushed it all over to the 4” pipe.
View Jimarco's profile
Jimarco
108 posts in 2600 days
#9 posted 05-08-2022 07:23 PM
I’ve tried a few different ways trying to catch saw dust from a miter saw… you can’t catch it all. This link is what I use now and works ok for straight and mitered cuts but will not work for compound miters. it’s quick and inexpensive.
This link is one that looks to work well and worth the time and effort
View tvrgeek's profile
tvrgeek
2404 posts in 3142 days
#10 posted 05-08-2022 08:35 PM
I put a plenum under the saw and taped up around all but a front gap for airflow. Hose to a Y with a hose on the OEM port. Works sort of OK. ( Ridgid)
View RyanGi's profile
RyanGi
385 posts in 530 days
#11 posted 05-08-2022 10:44 PM
I think the major problem with dust collection on a miter saw has to do with the incompatibility of a traditional dust collector and the miter saw itself. A large impeller dust collector is designed to move a high volume of air but at a low pressure. That means it’ll pick up fine dust well, but chips and course dust is harder for it to move. To pick up those larger, heavier pieces, shop tools that produce that type of debris tend to have confined cabinets and directional air flow. Think of a cabinet style table saw. There’s limited air inlet (usually the throat on the table) and the cabinet is sealed up to discourage unwanted airflow. The idea is that the chip production occurs between (and in line with) the air inlet and the dust port. This maximizes the airflow in the area the chips are produced for the best extraction,
Miter saws don’t (can’t) do that since, by nature, they’re an unconfined tool. So, in order to overcome this shortfall, one either needs to collect and direct the chips into a very focused area for the low pressure to be able to collect it, or the vacuum pressure needs to be highly increased.
Since building my high pressure DC system (Oneida Supercell) my dust collection woes at the miter saw have been greatly reduced…even with no modifications to the saw itself.
Without that high pressure, I think the only real way to get better collection from a miter saw is with dramatic funneling of the debris into the mouth of the DC pipe/hose. Unfortunately, the width of the funnel to collect all those chips creates an awful wide inlet for even a large impeller DC to move enough air to collect the fine dust as well.
I don’t want to say it’s impossible to do, but I think ‘good’ dust collection on a miter saw, using a traditional dust collector, is just really hard to accomplish.
-- Ryan/// I like chips...and sawdust...but mostly chips...with vinegar
View WoodenDreams's profile
WoodenDreams
1622 posts in 1404 days
#12 posted 05-08-2022 10:59 PM
For dust collection, I somewhat copied this for dust collection.
The dust ended up blowing out the front between the vinyl curtain. So I added a 1 1/2” hose at the miter saw dust port and fed through a 2” hole on the side and attached the hose to the side of the work station. Then I hooked up a shop-vac to that hose when using the miter saw. This eliminated about 70% of the dust. When I added a 2 1/2” under the front of the vinyl curtain to the dust collector. It eliminated 95% of the saw dust when I used both the 1 1/2” and 2 1/2” collection points at the same time. Now I don’t get any saw dust on the floor or blown at me
I should have made it wider, like in the first picture. You can see the 1 1/2” white tube comes out to attach shop-vac. And where the 2 1/2” hose tube goes in.
View Robert's profile
Robert
5007 posts in 2973 days
#13 posted 05-09-2022 01:40 PM
The was version 1. I’ve since modified the doors to go down lower. 1HP wall mount blower exhausted out side. Works well, not as good for miter cuts and wide boards.
View JIMMIEM's profile
JIMMIEM
262 posts in 2334 days
#14 posted 05-09-2022 03:56 PM
JIMMIEM
#15 posted 05-09-2022 04:01 PM
