Forum topic by skess | posted 02-02-2022 05:44 PM | 567 views | 0 times favorited | 18 replies | ![]() |
I’ve been trying to setup my miter gauge on my table saw. The blade I was using was that Freud 24 tooth ultra thin kerf framing blade. After a lot of back and forth adjusting, I have come to an understanding that this blade might not be very good for miter cuts. It was consistently giving me horrible cuts – not square and with a consistent notch at the beginning of the cut. |
18 replies so far
#1 posted 02-02-2022 06:37 PM |
You were on the right track of using a thin blade on a low HP saw and also it wastes less wood in the cut. But, thin blades are prone to flexing on thick or hard wood which is a problem in making precise cuts. Lots of small details like this to learn. In 40+ years I’m still learning. I guess that is the attraction of woodworking. -- Les B, Oregon |
#2 posted 02-02-2022 07:08 PM |
Hi Les, |
#3 posted 02-03-2022 12:28 PM |
1. Do you guys have a favorite normal (thick) kerf 7 1/4” cross cut blade? And 2. Same question for ripping? Favorite 7 1/4” normal kerf ripping blade? Blades that won’t flex too much (if at all). Thanks, Steve |
#4 posted 02-03-2022 01:43 PM |
For thin kerf blades, saw blade stabilizers will help. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#5 posted 02-03-2022 02:27 PM |
I didn’t think 7 1/4” blades came in different kerfs. One thing about miter gauges, if you don’t have a stop block, clamping the piece to the fence can be the difference between a clean cut. Have you checked to see the miter slot it parallel to the blade? -- Everything is a prototype thats why its one of a kind!! |
#6 posted 02-03-2022 04:09 PM |
Yea. With stop block and without – same result. And – I’m new to all this. So, I don’t know if manufacturers are making only thin kerf 7 1/4” blades these days. I happened to have an old Craftsman 7 1/4” which is a thick kerf blade. |
#7 posted 02-03-2022 11:19 PM |
A framing blade is called that because it’s designed for cutting framing (construction) lumber as quickly as possible where clean cutting is not needed. It might work OK for you for ripping, but crosscutting or cutting miters is definitely not its best use. For a clean miter cut, a blade with more teeth would be better. In the 10 inch blade category, rip blades are frequently about 24 teeth, combination blades about 40 teeth, and blades designed to crosscut are frequently 60-80 teeth; the shapes of these teeth differ as well. A 9” blade might have fewer teeth, but often not too far from these numbers. Try to find an inexpensive blade designed for the work you want to do, and test that before deciding the kerf is the culprit. You want something that says it cleanly crosscuts. Are you making a miter cut at 45 degrees, or are you crosscutting at 90 degrees? Sometimes terminology can get in the way. Definitely focus on the blade, but keep in mind that some blades are more forgiving of small saw misalignment than others. At some point you may benefit from a return to that topic. -- Alan in Wisconsin |
#8 posted 02-04-2022 12:08 AM |
I didn’t get to testing 45 deg cuts yet. The issue I’m having is at 90 deg cross cuts. |
#9 posted 02-04-2022 04:32 AM |
I had that same problem, even after building a 45 degree sled for box miters. I did exactly the same thing you did with a 7 1/4 blade. It has solved my problems. |
#10 posted 02-04-2022 05:54 AM |
If you get sufficient depth of cut with a 7 1/4” blade, use that size for now. They are much cheaper than less standard sizes: this thin kerf 40 tooth blade should cut cleanly and is under $15. https://www.amazon.com/Freud-D0740A-Finishing-Knockout-PermaShield/dp/B00008WQ2G?th=13 . It sounds like you did a careful job of alignment. You may have gotten a bad blade. If you cut very slowly you can probably minimize the problem, but I suspect it’s not simply due to the thin kerf. -- Alan in Wisconsin |
#11 posted 02-04-2022 02:14 PM |
A couple of things: You say you’re a newbie, so there may be issue with your technique. Try making the cut with the wood clamped to the miter gauge so that you can eliminate any side-to-side pressure and check your cut. Use one hand on the miter gauge handle to push it through rather slowly to give the teeth time to remove the waste. Do not touch the wood or the miter gauge with the other hand. (A thicker blade might be able to withstand any pressure to the side of the blade better than a thin kerf blade) If that didn’t correct the issue then it is probably not a technique issue, so you need to test the hypothesis of the blade flexing during the cut. Mark the the top of your board with an arrow pointing toward the blade and make a cut. Verify that it is NOT 90 degrees. Put the board back on the miter gauge with the arrow pointing toward the blade again. Line the very front corner of the wood up with the blade such that the front corner barely kisses the blade. It should be almost cutting nothing. Push the wood slowly through the blade. It should not cut very much from the front of the cut, but start cutting more and more as you push it past the blade. If it cuts more at the back of the original cut than the front, then there is an issue with the blade flexing. If it doesn’t cut anything or cuts parallel to the original cut, then you have a setup issue. -- Tony, SW Chicago Suburbs |
#12 posted 02-04-2022 04:04 PM |
Thanks guys – Tony – I’ll try the hypothesis test next when I get a chance. Thanks for the tip. Alan – thanks for the link. I’d like to try that blade out. |
#13 posted 02-04-2022 04:07 PM |
Hey Bob, Thanks, |
#14 posted 02-06-2022 04:53 PM |
Tony – I ran the test that you described and definitely the blade flexing. I then put the thicker blade back on and made a cut and it was square again. Then, I tried the same test with a 3/4” plywood scrap – about 7” if a cross cut. Same result. When I get the 40 tooth freud finishing blade – I’ll see how that does. But, my preconceived notion is that the cut will be smoother but that it will flex also. Hopefully, I’ll be proven wrong about the flexing. I’d like to try ripping with this freud blade to see how it performs with that. But, I’m afraid to rip until I get some sort of splitter in place. I’m still thinking about what to do about that – diy or look for some aftermarket solution. That’s today’s update. |
#15 posted 02-06-2022 08:08 PM |
One further comment re: using the miter gauge. When pushing the wood through the blade, make sure you apply lateral pressure on the miter gauge toward the blade. A few thousands “slop: between the miter gauge bar and the table slot can throw off the cut. |
Forum | Topics |
Woodworking Skill Share
13556 |
Woodturning
3018 |
Woodcarving
621 |
Scrollsawing
438 |
Joinery
2084 |
Finishing
6732 |
8200 |
34249 |
CNC Woodworking
387 |
Hand Tools
6788 |
Jigs & Fixtures
1926 |
Wood & Lumber
7620 |
1700 |
Focus on the Workspace
2752 |
1296 |
Woodworking Trade & Swap
5586 |
LumberJocks.com Site Feedback
2434 |
Coffee Lounge
9911 |
